Lights on a Case ROPS
   / Lights on a Case ROPS #1
MrJoe
Southbury, Conn.
Case IH DX24E
Good Day: One unexpected side benefit of my Case DX24E has been the ease of mounting lights to the ROPS. It has four 3/8" holes factory drilled front to back on the top of the ROPS. I just took perforated angle iron, bolted it to the top, added a light to a switched wire to the under seat aux. plug /forums/images/graemlins/smile.gif
Like most of you I needed more light but did not want to drill or weld to the ROPS /forums/images/graemlins/frown.gif The factory did if for me /forums/images/graemlins/smirk.gif
   / Lights on a Case ROPS #2
</font><font color="blue" class="small">( Good Day: One unexpected side benefit of my Case DX24E has been the ease of mounting lights to the ROPS. It has four 3/8" holes factory drilled front to back on the top of the ROPS. I just took perforated angle iron, bolted it to the top, added a light to a switched wire to the under seat aux. plug /forums/images/graemlins/smile.gif
)</font>
How many lights did you install?
Can you pivot them up and down?
Can you rotate them 360 degrees.
Can you illuminate all the way around the tractor with them?
I just put one on the bracket, thought I would see if that was enough. So far it is. I bought a cheapie trapozidal pattern light from Auto Zone($10). The pattern is Ok but I think I'll try a flood next.
I can adjust the light up and down, side to side, backward, it's on a ball mount bolted thru the perforated angle. Has to be shifted by hand each time but 95% of the time it's looking ahead. There is enough amps left (w/v=a) in the aux. plug (10a.) to run another light so I might try that.
The whole setup cost about $25 by the time I was done. Switched plug wire from Radio Shack, light from Auto Zone, perforated angle and bolts from Home Depot.
I suspect the ROPS holes are for mounting a canopeas /forums/images/graemlins/wink.gif on top but it does what I want for now.
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
Wolverine Slide on Manure Forks (A50515)
Wolverine Slide on...
