Lights not working
/ Lights not working #1
jplshort
Kioti ck3510se hc
hello everyone I just bought a new kioti ck3510se hc. I bought it new have had nothing but problems with the dealer. Well after finally getting the tractor home I used it for 2 hours before realizing the dome light and work lights on the cab dont work. So before calling the dealer I checked the fuse and checked all the connections I could find. Still nothing. Called the dealer which I couldn't reach they called back and left a message to check the fuse and jiggle the wires. Well I finally took the panel apart and found i have power to the switch but the switch doesn't work. Also there is a clicking noise which I assume is the relay if I jump the wires and the lights still don't work. Does anyone know where the relay for the work lights is also would that effect the dome light.
Once I called about the switch it took the dealer 20 minutes to find the part number to order me new one. Next call will probably be to order a relay which means another 20 minutes or more of my life gone.
Thanks for reading
/ Lights not working #2
Welcome to TBN! The parts book shows the relay in the top of the cab on the rear left corner. Hope that helps!
/ Lights not working #3
Welcome to TBN.
"they called back and left a message to check the fuse and jiggle the wires"....:duh:
Double check if you wires aren't pinch/damage tractor to cab.
/ Lights not working #4
Welcome to TBN.
Nice new tractor jiggle the wires HAHA very sad dealer service ............:thumbdown:
/ Lights not working #5
Like mentioned already. Check the wires going up into the cab for damage. OR, have them pick it up since they obviously never checked out the tractor before delivery.
They said they checked everything and it worked before they shipped it. So far I haven't found any loose or damaged wires. I did find a few wires that really need to be rerouted. As far as being a sad dealer... well besides the lights not working ordering the new 72" back blade and a 72" land plane and receiving an 84" used back blade and the land plane was removed from the list.
/ Lights not working #7
Wow, why did you accept the tractor that way without the right attachments?
Well they didn't charge me for the land plane and the 84 in blade is an upgrade over the 72 given the functions of the different blades. Also I needed the tractor for this week because of my vacation from work. They are sending a switch if that doesn't work I'm telling them to pick it up and fix it.
thanks I will check the relay
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
Pallet of Chains & Binders (A64127)
Pallet of Chains &...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
CrustBuster 3800 Drill (A66285)
CrustBuster 3800...
213064 (A64276)
213064 (A64276)
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
