Lightening Killed My TV
   / Lightening Killed My TV #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
We had a lightening strike near our house yesterday. If flipped the breaker in the TV room. We had the TV (40" Sony Bravia), Sony DVD player/entertainment unit (cheap), Apple TV box ($100) and DirecTV box all on the same outlet using a cheap power strip.
When I flipped the breaker back on the DVD player came on but TV, DirecTV and Apple TV box will not come on at all, even when plugged into new power strip and different outlet. TV cost $800 and is less than 2 years old.:weepy:
It also knocked out our cable internet service at the pole in out neighbor's yard. That has been repaired.
Questions: Are there any other tests or checks I need to do before chucking the TV in the garbage? Home owner's deductible is too high to help. Is there any chance that it would be financially beneficial to try to have it repaired? Any advice or previous experience with this appreciated.
   / Lightening Killed My TV #2
I'd be surprised if the TV is worth fixing, or even can be fixed, but I guess it wouldn't hurt to take it to a TV repair place and get their opinion. I don't know what else you can do.
On August 4, 1998, we had a lightning strike that killed one digital alarm clock, one 3-way table lamp, another 3-way touch lamp, an old small color TV, the DirectV satellite receiver, and two cordless telephones.
But at that time I only had $200 deductible, called my insurance company, was given a claim number and the name of an adjustor who would be contacting me, and he pretty promptly called. Before I called, I looked up my old records, knew what the items cost, where they came from, etc. and the adjustor just took my word for everything and sent me a check. I thought he'd at least come out to see the stuff, but he said to just throw it away. The DirecTV folks did want the old satellite receiver sent back to them.
   / Lightening Killed My TV #3
Make sure you check every GFI in your house ,when i got hit it took them all out.
I was at the neighbors when the storm went thru that evening, less than a month later the neighbors barn that we were working in when my house got hit was burned to the ground by lightning. Fire marshal determined that lightning connected with a iron hayrack system in the loft and ignited several points that had contact with the wooden structure.
Not a good thing to be woken up by accetelyene tanks exploding in the middle of the night.
   / Lightening Killed My TV #4
Most likely a total loss. But, it won't hurt to take the back off the TV and look. Replace the fuse. See if anything else looks broke or needing replacement. You might just get lucky. Good luck.
MoKelly
   / Lightening Killed My TV #6
When you get new "stuff", make sure to buy a UPS too! (Uninterruptible Power Supply) They are about $150 and well worth the investment. It probably would have saved you the headache you are going thru now. This is not a surge protector I'm talking about built into a power strip. Places like Best Buy and Walmart carry them.
I have 5 of them. On every TV (with components) and Computers at my home!!
Looks like this:
AMERICAN POWER CONVERSION 1080VA Battery BackUp System BN1080G - Best Buy
   / Lightening Killed My TV #7
See if the TV has a fuse. My be a simple repair for a TV shop (if you can find a TV shop). But most likely, its toast.
Lesson learned... get a better power strip, one that has a guarantee for lightning strikes. (I should take my own advice :)).
   / Lightening Killed My TV #8
Yes, check the fuses. Google and youtube have some very good tv repair stuff for the newer Tv's. You'll have to take off the back panel and do some research. Please let TV sit unplugged for a few hours to discharge the capacitors as they can keep strong power for a while.
   / Lightening Killed My TV #9
Lightning fried one of three HDMI circuits in our sony. We only use two of them at a time so all it cost us was a service call from the repair guy.
Our tv was protected by a UPS that was protected by a surge protector that was protected by a whole house surge protector at the meter. I guess it was just our turn.
   / Lightening Killed My TV #10
I've lost 6 Craftsman garage door openers over the past decade due to lightning strikes. I've got breakers on the outlets, and I put good quality surge/spike protectors between the outlets and the openers the last couple times. Turns out the strikes aren't coming through the lines. The lightning has been hitting pine trees about 75 feet from the house, and it's the EMP being conducted by the wires from the obstruction safety sensors blowing through the circuit boards. (The IR sensors on each side of the doors are being burned out too.) The last time even blew past the several iron core retarders I wrapped the sensor wires around to fry the circuit boards.
1997 International 9300 Day Cab Tractor (A52384)
1997 International...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
John Deere 8400R MFWD Tractor (A53342)
John Deere 8400R...
2024 JOHN DEERE 461M LOT NUMBER 60 (A53084)
2024 JOHN DEERE...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
