Light weight wood chip bucket or modifications?
   / Light weight wood chip bucket or modifications? #1
KanakaRick
Truckee, CA
KIoti DK50S
I have a Kioti DK50 and I am moving a bunch of wood chip mulch around. The 1/3 yard bucket is the equivalent of a wheel barrow load. Since the chips are so light, I'd like to find either an oversized bucket, a poly bucket (if they make one) of some sort of easy mod I can do to increase the capacity of my bucket. Ideas?
   / Light weight wood chip bucket or modifications? #2
Some fabricate plywood bucket extensions.
Here is a germane thread: https://www.tractorbynet.com/forums/build-yourself/112403-2cuyd-leaf-bucket-scut-works.html
I just finished moving 100 cubic yards of large chip Pine bark mulch with my 1/3 cubic yard FEL bucket.
Moving the chips took awhile but I could place them right where I wanted each bucket full.
(11/2018 price for large chips = $12.00 per cubic yard = $0.44 per cubic foot. Bagged mulch from local hardware store = $1.33 per cubic foot.)
   / Light weight wood chip bucket or modifications? #3
I would think with some plywood and 2x4's you could make a really big temporary bucket expansion for your OEM bucket.
   / Light weight wood chip bucket or modifications? #4
The suggested plywood should work good.
My neighbor uses a set of forks with a big metal box on them that looks like it used to be kind of squarish tank that he cut.
Edit: So maybe some clamp on forks and a stock tank or plywood box ??
I use a dump trailer
gg
   / Light weight wood chip bucket or modifications? #5
I had to deal with pine needles at my last property so I came up with this piece of aluminum and an old frame that was laying around.
Worked really great and I had 100% dump with bucket straight down.
   / Light weight wood chip bucket or modifications? #6
Stimw - very interesting. On all of my 80 acres I have ONE tree with leaves. They fall and the fall winds blow them away.
However - I have a complete forrest of ancient Ponderosa pines. The dry summer and fall winds cause the pines to dry out and they shed needles by the bundle. It gets thick enough to suffocate the lawn - if I don't remove them.
Pine needles are tough to rake. So I set my riding mower at 2 and a half inches and "mow" them all into a single row in each of my three large yards. Then I just have to rake and gather the one row in each yard.
Looks like you get lots of experience raking pine needles also.
Great ideas gang.... Now you got me thinking....
   / Light weight wood chip bucket or modifications? #8
Geeze Rick - you are moving wood chips - not leaves or pine needles. I AM sorry. If you generate the chips - why not figure a way to catch them in something that you can pull around and not have the hassle of picking them up. A light weight wagon - if you generate the chips - blow them into a wagon and pull it around.
I chip 750 to 900 small pines every spring - thinning my stands of Ponderosa pines. Size is - 1" to 6" on the butt. I blow the chips into my farm wagon. A 4'x8' sheet of plywood attached to the very back end board keeps the chips in the wagon. I sure don't need this heavy a wagon - ten ton running gear - but its main use is to haul huge rock and ten foot chunks of Ponderosa pine. I bought the running gear brand new and built the wagon from plans found on the internet. The brand of running gear is Horst. They make much lighter gear for smaller lighter wagons also. For me - it was an interesting fun and easy build.
I live in Truckee in a sea of sagebrush that had a hot fire run though about 40 yrs ago. So there is no forest liter....just silt between the sagebrush. Due to the fall being very dry, I am taking the bull by the horns and pulling all the sagebrush with my backhoe and then I plan to cover the silt with wood chips to keep both the flashing fire danger down and the dust down. The chips are not generated on my own 10 acre property as there are only 10 tress on it and I don't want to cut down my summer time shade. So I am having the local tree companies divert their loads from the local dump to my place "Free dumping". I cannot use a trailer as my property is extremely rocky...I can barely get the tractor out there, let alone a trailer. I've been looking online for someone who builds a oversized bucket, that has expanded wire in the low stress areas, to keep the weight down, but it doesn't look like anyone does that. Too bad as I would be buyer.... so for now I am looking for good ideas.....
Blue Diamond Quick Attach Brush Mower (A50514)
Blue Diamond Quick...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
UNUSED X-STAR SKID STEER QUICK ATTACH LAND LEVELER (A51243)
UNUSED X-STAR SKID...
