Light weight 3 point offset mower
   / Light weight 3 point offset mower #1
bikerdib
Platinum Member
Texas
Kubota L4701
I'm in the process of having a pond put in at a property I purchased last year. Three of the inner banks will be pretty steep and I will need some way of maintaining the grass/brush other than my heavy duty handheld weed wacker or my walk behind weed wacker (bank will be too steep for good engine lubrication). I don't expect to have it lawn manicured but want to mainly keep the grass and tall weeds knocked down to 6" to 8" tall. A sickle bar mower would be good but they are quite costly. DR makes a 3 point offset string trimmer but unfortunately at 16° up or down, it doesn't pivot downward enough. Titan Attachments has a similar unit but I think it would have the same limitations.
I'm looking for ideas.
   / Light weight 3 point offset mower #2
Round up :laughing:
   / Light weight 3 point offset mower #3
Round up :laughing:
As much as I like Roundup for things I cannot mow conventionally, it's not good on things like this where erosion is a real concern.
I think a sickle is going to be the most effective. But make Sure you get a belt driven one. One with a pitman arm severely limits the angle in which it will operate
   / Light weight 3 point offset mower #5
Your looking at a lot of money for a side shifting orchard and vineyard flail mower. If you cannot afford a side shifting orchard and vineyard flail mower you should tell your contractor to lake the slopes of the pond less than 15 degrees as there is no way you will be able to mow them safely with a higher angle.
You want a less than fifteen degree slope as it will create a wide grassy area that you can mow with a lawn mower and you will not have any erosion if you lay down a grass seed mat right after you have it graded.
You should look at the smallest Del Morino Side shifting orchard and vineyard flail mowers at Everything Attachments and decide from them there.
If your tires are loaded with liquid ballast you should have no problems. If the TYM tractor is all your using for mowing a side shifting orchard and vineyard flailmower will do all your mowing.
If you only have about 400 feet of bank edge a buying wide rolls of weed barrier fabric from Farmtek it will be a less expensive option for you and it lasts for ever.
You will need to purchase a box of ground staples to secure the weed fabric and install them on three foot centers but they will last as long as the weed fabric.
When you purchase the wide rolls of weed barrier fabric you can take the top edge and bury it in a small trench and then cover it and it will aid in holding the fabric in place.
You still need the ground staples to properly install the fabric but you will be glad you did this. You can use a stone mulch or a brick mulch and eliminate weeds at the same time.
I would lean towards a sickle bar mower before a flail due to the weight hanging out. The flail is OK long as everything goes well but all it would take is an unseen erosion hole or bank cave in to tip things in a bad way.
The weed mat with crushed brick is something I hadn't considered but since I'll need it on 3 banks of a one acre pond it may add up to more cash than a sickle mower.
The sickle mowers from Everything Attachments look interesting. Any opinions?
   / Light weight 3 point offset mower #7
I use a bushhog with no top link attached or now with a chain and shackle so the length can be easily adjusted. As long as you don't lift it high enough for the PTO shaft to strike the mower body (why I usually have the chain) you can back up and the tail wheel of the mower will drop down the pond bank and do all the cutting you want. It is time consuming doing all that reversing, dropping the mower, driving forward, lifting the mower and reversing again BUT it is a lot cheaper if you already have a rotary cutter.
Just be careful getting the blade in the water, that really pulls the engine rpms down.
RSKY
   / Light weight 3 point offset mower #8
Hello bikerdib,
The six foot wide rolls of high grade landscape fabric from farmtek come in very long lengths and you could cover the pond edges the first year with the weed fabric and landscape fabric staples and then cover the fabric with a broken brick or red granite mulch if you can buy it in bulk locally. Your going to spend less money doing it that way than buying a new mower.
You just have to make sure that the outer edge of the fabric is buried to prevent it from being pulled up with a rotary mower.
FarmTek - Hydroponic Fodder Systems, Farming & Growing Supplies, Hoop Barns, Poultry & Livestock Equipment, High Tunnels, Greenhouses & More
You just have to decide what width you want and the life span/fabric type you want as you can purchase it in 100-600 foot lengths 6 or 12 feet wide.
They have pond liner fabric as well if you want to look at that.
   / Light weight 3 point offset mower #9
I have a dr walk behind brush cutter, 20hp and 30 inches wide. Cuts down big stuff easy...not a tractor implement by any means, but might be an option if you can't find something.
RSKY
That's kind of the way I cut around my pond at my weekend place in the woods. I have a hydraulic toplink so I can easily adjust the cutter to follow the slope. Hydrostatic drive makes it easier but still time consuming. Just have to be very careful not to wash the tractor in the pond.
2016 JCB 507-42 Telehandler (A50490)
2016 JCB 507-42...
2019 Nissan Frontier SV 4x4 Ext. Cab Pickup Truck (A48081)
2019 Nissan...
2022 Club Car...
1991 International 4900 Box Truck (A50397)
1991 International...
2011 Jeep Grand Cherokee Overland 4x4 SUV (A48082)
2011 Jeep Grand...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
