Light Problem on 5155
   / Light Problem on 5155 #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
Bought an almost new Mahindra 5155, it had set outdoors at the dealers last winter. Had some, after market, LED light installed. Tractor works great, but no lights except the ones with independent switches(4 ways and work light and LED's). I have checked the fuses, they are mini's and difficult to remove and check, all appear good. The $300 4 way light switch, turn signal, horn and high/low beam headlights, may well be the problem, but changing it is a last resort. There are relays in the fuse block for high beam lights, low beam lights. How do you check those relays?
Any other ideas?
   / Light Problem on 5155 #2
Any other ideas?
Ruebicon Aftermarket Mahindra parts has the light switch for less than $100.00
2022 New Holland C327 Compact Track Loader (A55315)
2022 New Holland...
3 PT HITCH SPRAYER (A57192)
3 PT HITCH SPRAYER...
10' CONTAINER (A57193)
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
