Light Kits on 4000TEN
   / Light Kits on 4000TEN #1
BobJG
Ontario
John Deere 4310
Can anyone shed some light (no pun intended) on what is the best way to put more front and rear lighting on a 4310 tractor. I know JD has two light kits and I was wondering how easy to install those are, also whether I need the bigger alternator, and whether or not there are better aftermarket lighting kits available.
Is there a simple location to plug in a light set?
I don't need the lights now, but when old man winter arrives I find myself out moving snow in very dark conditions and was a little dissapointed in the stock lighting on a 4310.
   / Light Kits on 4000TEN #2
They are very easy to install and are very good lights.
Instructions come with them and the instructions are easy to follow.
   / Light Kits on 4000TEN #3
For my 4710 I got the light guard kit for the flasher lights that are mounted to the outside of the roll bar & 4 work lights from John Deere. If I remember correctly, the 4 work lights were in 2 kits. The 2 foward facing lights are mounted to the top side of the guards on the outside of the roll bar. The 2 rear facing lights are attached to the inside of the roll bar with the same bolts that attach the flasher lights.
Chris
   / Light Kits on 4000TEN #4
I got the John Deere kit and it works great for snow removal. The lights are slightly angled out. I'm using the stock alternator and it seems to work fine.
   / Light Kits on 4000TEN #5
On my old 4300 I had the stock dual rear work lights and they were very bright probably pretty close the same brightness as my new 55 W KC lights.
2020 KUBOTA RTV...
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2019 Chevrolet Malibu Passenger Car, VIN # 1G1ZC5ST5KF136071 (A51572)
2019 Chevrolet...
NEW Fork Extensions (A53002)
NEW Fork...
