Light kit for a M 6800 Kubota
   / Light kit for a M 6800 Kubota #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I have searched for info on adding lights to tractors, but wondered if anyone with a M 6800 or similar tractor has added lights. My grapple makes the factory lights useless. I need two forward facing lights and a rear worklight. Is there a dedicated circuit available for this? Please educate me on how to do this. I see many different styles of lights available. Is there a factory Kubota kit for this and if so, is it as good as aftermarket lights? What are my electrical limits in terms of amps?
I use my tractor in the woods, so it must be undermounted to the ROPS (no Cab) and be able to withstand an occasional low limb. I never drive on highways. Can someone walk me through the process of doing this? I want to do it right, so cost I don't want to cut corners. Thanks for your help!
   / Light kit for a M 6800 Kubota #2
Though I can't comment on forward facing lights I did mount a rear light above my 3PH on my M4800. Just in case you don't know at the base of each upright of the ROPS there should be a factory installed power pigtail. It'll be stubbed out from an electrical flexible conduit. I tied mine into that along with an inline fuse and ran it to a weather proof switch and on to the light. Anyway, thought I might mention it. It might assist in your installation.
Jay
Thanks Jayste. I had heard there was a lead in the wiring harness, but did not know where. Any pictures of your rear light? What light did you use and where did you mount it?
   / Light kit for a M 6800 Kubota #4
HCJ, I bought them at Atwoods which our local version of TSC. They are standard rectangle shaped and mounted them on the back lip of the body next to the bracket for the SMV placard. I'll have to get you a pic of it this evening.
Jay
   / Light kit for a M 6800 Kubota #5
I mounted two trapezoid lights on my M6800 under the front of the canopy and a flood light on the rear. You should be able to mount them under the roll bar with good results. As you are not suppose to drill or weld the roll bar you should use clamps. I installed a separate light switch and ran power to them. If mine (10 years old now) had a wiring harness on the roll bar missed it.
I will point out to you the draw back of this light set up is, bugs. Now if it is winter use only little issue, if summer nights in my part of SC...well get the insect repellent for a light at night draws them. I got so tired of the bugs and shifted work some to where I seldom use them.
Harold, It was pooring down rain last night when I got in so I didn't get that pic. I'll try and do it this evening.
Jay
Thanks! Don't go to too much trouble. I read more on various posts and have decided to try some LED lights by Truck-Lite. I ordered three today, two forward facing trapezoidal floods and one rear flood with a shorter projection. They are a little pricey, but sound perfect. Lower power draw than halogens. I plan to mount them on the underside of the ROPS, and I will probably drill my ROPS to install them. I know that is forbidden, but I can't see how several tiny holes will compromise the integrity of the bar. I will probably switch them all together. Where did you place a switch?
   / Light kit for a M 6800 Kubota #8
Hey Harold,
I was able to get those pics. The first one shows the light and where I mounted it. The second shows the stubbed out pigtail on the wiring harness by the ROPS. The 3rd one shows the location of my switch. My original plan was to mount the switch and access the power at the steering column area but found the power source at the back so just made it simple. Anyway, I hope this helps. Tractor is pretty dirty I was doing some brush hogging last weekend.:D Tractor time!:D
Jay
   / Light kit for a M 6800 Kubota #9
Thanks for taking the time to post these pics. That looks good. I thought about one rearward facing light in the middle of my ROPS, but your lower install may be better in terms of light projection at your implement, and keeping the bugs away form your head.
By the way, I like your "tool box". I guess you also feel that the Kubota factory box is worthless. It is way too small.
Don't worry about your dirty tractor. If it was clean, you lose credibility!!
Thanks again, Harold
   / Light kit for a M 6800 Kubota #10
No Problem, Harold. Thanks for the kind words. Yes, the Kubota tool box that came with the tractor is so small you can't even see it!:D Probably because mine didn't come with one!:D:D
Be sure and post some pics of your "add-on's".
Jay
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
Kubota R530 (A50120)
Guard Rail Joints (A51692)
Guard Rail Joints...
