light hydraulic oil leak on i3040
   / light hydraulic oil leak on i3040 #1
Alaska247
Alaska
3040i
I'm hoping there's someone on the forum that has mechanic experience with an i3040. My tractor has developed a small but persistent hydraulic oil leak. It is coming from the rear axle where the brake level penetrates the case. I'm assuming the O-ring just needs to be replaced. I've added a pic of the parts diagram below for easy identification. The red arrow indicates where the oil is leaking.
My question - Can I pull out the brake lever, replace O-ring and put the lever back in without something falling out of place on the inside of the case? In the picture below, I'm afraid that if I pull out #23, that #18 will fall out of place and I will have to open the case to put it back together.
Thanks in advance!
   / light hydraulic oil leak on i3040 #2
You might call the dealer, my dealer tells me if I can fix it or bring it in.
Komatsu 330 Excavator (A51573)
Komatsu 330...
43029 (A51691)
43029 (A51691)
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
2012 FORD E-SERIES 11 PASSENGER VAN (A52472)
2012 FORD E-SERIES...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
