LIght Guard
/ LIght Guard #1
PHPaul
Platinum Member
Downeast Maine
Kubota B2650 with cab, Pasquali 986
I've lost a couple of lenses on the upper flashers on my Kubota B2650HDSC. Mowing under trees and such they get rubbed on a lot.
Blowing snow after the recent storm, a lot of the trees next to the drive had branches weighed down with snow and I finally broke one plumb off. Ordered a new one from Messicks, but decided I'd better do something to protect them a little better as rubbing on branches is going to be an ongoing problem.
So:
A simple ring rolled out of 3/4 x 1/8 flat stock, with a tab welded on the bottom that the mounting post on the flasher assembly goes through. The light actually sits behind the ring (towards the front of the tractor) but I'm hoping it will deflect branches enough to protect the light.
Push comes to shove, I'll make a double ring type with a guard ring on both sides of the lenses.
/ LIght Guard #2
Some of the equipment at the DPW I work at, has guards like that on the strobe lights. They work well.
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
(4) New Caterpillar Skidsteer Loader Tires (A66408)
(4) New...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T800...
Skid steer Backing Plate (A62679)
Skid steer Backing...
2014 Freightliner Cascadia Semi Truck (A66285)
2014 Freightliner...
