Lifting hitch???
/ Lifting hitch??? #1
bowserj
Latrobe
John Deere 2025R
Several years ago, I remember seeing a receiver hitch that attached to the 3 point where there was no toplink as it was part of the hitch and pivoted as the arms went up. I believe there was a second "arm below it that pivoted in sync to keep the attachment point level.
This design increased the lifting range of the device.
I am considering building something like this, and was looking for this post to compare it to what I have in my mind.
I don't remember what it is called, and all of the search terms I have tried have come up empty.
I also remember concern that this would put stress on the toplink in directions it was not intended, and just wanted to see what everyone had to say before attempting a build.
Does anyone know what I am talking about or could point me in the right direction?
Thanks
Here is a basic drawing in paint of what I have in mind.
/ Lifting hitch??? #3
I saved this picture in my projects file. It came from Omni Mfg, when I bought their Transformer 3 point hitch.
And a hydraulic one:
What are you wanting to build?
/ Lifting hitch??? #4
Here is an other way to do it - might spawn an idea. I haven't thought it all the way thru but maybe if you had a fork on the end of the lift bar like lower lift arms and you used a normal top link but longer you could get more lift for your mower with a simple mechanism
gg
/ Lifting hitch??? #5
... and another one. Modified engine lift.
/ Lifting hitch???
Exactly what you are showing in the first picture is what I am going for. I have a set of log tongs, and even when just using a change, I often don't have enough height attaching to a hitch to drag the logs without digging in and tearing things up. If I could get another few feet of height, I would be able to use the tongs without issue.
/ Lifting hitch??? #7
Since you are new here and probably don't know to click "Reply With Quote", I will guess you mean me, cause I am the one that posted three pictures.
Here is the first one again and one with adjustable lift holes:
From an image search.
/ Lifting hitch??? #8
The biggest problem with something like that is going to be pulling the front end off the ground. It’s a long lever so it’ll raise slow so rollover isn’t likely but it’s still not very useful if the front end is off the ground.
/ Lifting hitch??? #9
The biggest problem with something like that is going to be pulling the front end off the ground. It痴 a long lever so it値l raise slow so rollover isn稚 likely but it痴 still not very useful if the front end is off the ground.
That is what steering brakes are for :D.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2011 Chevrolet Express 2500 Cargo Van (A61573)
2011 Chevrolet...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
1055 (A63291)
1055 (A63291)
