Lifting capacity
/ Lifting capacity #21
J_J said:
On my 1445, there is a small block at the left rear that has two relief valves.
As far as testing, or adjusting, you can plug a gage in the circuit and adjust. You can do this by teeing in a gage, and try to lift an imoveable object, that way, you can see and hear when the relief valves are operatig. Before I put a hydraulic gage in my system, I was having trouble with the lift capacity , which was very low. PT told me to send them back to them, and they would check the relief pressure. I could have taken them to a local hydraulic shop for testing, Anyway, they tested OK. It turned out to be the lift pump, which I believe was leaking internally. A new lift pump fixed my problem.
Thanks JJ. I like the idea of installing a pressure gauge. I don't want to get greedy with the lift circuit but it would be nice to know that I'm getting every bit it was designed to do. And hope I'm Not being to dumb here, but do you mean left rear of pump or engine compartment?
/ Lifting capacity #22
One additional thought. I have seen specifications for pressure and flow for the PTO circuit. I have never seen specifications for the lift circuit. The pressure spec might be the same and might be different. I think it would be prudent to contact PT before changing any safety valve setting!
/ Lifting capacity #23
I agree about the variable rating per attachment. I doubt that PT wants to complicate their marketing stretegy to rate as you say, or they are too lazy to do so. They are not much on documentation.
/ Lifting capacity
My relief valves are located close to the left rear wheel . My relief block assembly looks like an aluminum block with hoses coming in and out. The relief valves used by PT are screw in cartridges. They can be taken out and set with a hydraulic test set, or hydraulic shop, or you can do it your self with a gage plumbed in the circuit. The setup is real simple to make. Insert a tee fitting in the circuit and install a female quick disconnect. On the gage, screw on the male part of the quick disconnect. I would recommend liquid filled gages. Just plug it in the circuit you need to check. I leave my gage plugged in all the time. You could do this for all three circuits, and you can then do most all your hydraulic trouble shooting.
/ Lifting capacity #25
Thanks. Found them right where you said they would be.
/ Lifting capacity #26
I went over to a neighbors house to move some dirt. It was in a pile and very wet. I attached the 4 in 1 bucket with Markham tooth bar, but I forgot to put on weights. I did the PT pucker about 4 times and gave up. That's the last time I will try to dig without weights. I made a new weight holder that is shorter than the old weight box so it takes less room in my garage. I welded a Kubotoa 55 pound weigth to a 2 inch receiver tube and put it in the two inch receiver in the back. I left the tube about two inches longer than the back of the weight so I can put my other weight on if needed. See attached picture. I will probably weld an angle iron across the end to support the 2nd weight. I do not want to pick up a unit with two weights.
/ Lifting capacity #27
Bob,
You probably know this, but if those weights are cast iron, watch out for cracking right next to the weld. DAMHIK(Don't Ask Me How I Know). I bet one of those weights falling on your foot might make an owwie...
Gravy
/ Lifting capacity #28
Gravy said:
Bob,
Gravy
I did not know that. It was a little difficult to weld and I had to put a lot of heat on it. Maybe I should weld some steel around it. Do you have any suggestions on how to weld such a material?
/ Lifting capacity
On welding cast iron. I believe that you have to heat up the cast iron with a torch before you start welding. I don't know the correct temp. You could just bore some holes in it and bolt on some plates.
I know they heat up engine blocks before they weld
/ Lifting capacity #30
Bob999 said:
Perhaps you were told that the rating is at the attachment point. That is the only way a tractor could have a single rating as I understand it. This is because each attachment has a different weight and the effective point of the load differs (it is much further out with the mini-hoe than with a bucket). If the lifting capacity were listed at other than the attachment point PT (and any other manufacturer for that matter) would have to publish a table of lifting capacity--with the small bucket = xxx, with the large bucket = yyy, with the mini-hoe =zzz, etc.
Isn't the standard the weight that can be lifted 500 mm out from the attachment point, and the attachment weight has to be subtracted from that?
On my b3030, I haven't put the rear wheels in the air. Have come across situations where the bucket wouldn't lift while digging. The hydraulic relief gave. Not sure if that will be helpful. It certainly seems reasonable to me that a Powertrac would need weight in the rear, but I'm coming at that from a CUT perspective - never owned a PT, but I think they look neat and I sure would love to play with one.
/ Lifting capacity
I believe that the greatest lifting capacity is at the point where the hydraulic cylinders contact the lifting arms, or behind the lifting point. You have to work out the math to add distance from the point of contact. Theoretically, if you have a 3000 lbs lifting cylinder, it will lift 3000 lbs, plus maybe some reserve. What would the lifting capacity be at 1 ft, 2 ft, etc. An analogy might be something like, a person might lift a 5 gal bucket of water, up close the the body, but try to lift the 5 gal bucket of water with a straight arm. Very difficult. The further out you try to lift, the load capacity will decrease
/ Lifting capacity #33
That's a good analogy, J_J. I ran into the same questions when designing the backhoe and figuring leverage. 1 foot of mast on either side of the pivot point = 1:1, so a 30,000 pound cylinder could provide 30,000 pounds of force on the other end. 1 foot of mast on the cylinder side and two feet of mast on the other side of the pivot point = 1:2, so only 15,000 pounds of force on the other side. 1:3 gets you only 10,000 and 1:4 only gets you 7500.
You have to figure out the power of the lifting cylinder and then all the distances to pivot points, then the counterweight of the tractor with our without operator, etc...
All I know is our little PT425's hydraulics will lift the rear of the tractor off the ground if any attachment is stuck under an imovable object. I can keep adding weight until the thing either hits the reliefs or snaps in half, whichever comes first. I don't want to find out :eek:. A heaping large material bucket full of stones is plenty of bite for me, thank you. :D
/ Lifting capacity #34
Yes, I understand that - hence the standard being half a meter out from the lift point. It seems agreed that that gives a fair point of comparison for real world usage, as very few of us actually lift from the bottom of the cylinder... So by standard, I mean across tractor lines
/ Lifting capacity #35
I did a little research on welding cast iron and it was confusing. One said to heater to 400 to 1200 deg. F, another said 100 F was OK, another said cold was OK. Another said weld only about one inch at a time. I did this, so maybe I am OK. I pulled on the weight real hard and did not get any movement or breakage. A little cracking in this application is probably not going to hurt. Does anyone have an more experience in this area?
/ Lifting capacity
Bob Read this article.
The most important thing for you to understand is that electric welding on cast iron is actually the very worst decision you could make to attempt to repair your cracked cast iron part. If you want to make a complete mess of your part, go ahead and arc weld it with nickel rod. Cast iron cannot stretch and withstand the contraction and hardening caused by cast welding with preheating below 1200 deg. F. The brand of welding rod does not make a very big difference. It's the heat that causes the changes to the cast iron itself. Sure the nickel weld is machineable but the cast iron will become as hard as a drill bit or tap and therefore will prevent the proper machining that is often required. 50% of the casting repairs we see have been arc welded on with disastrous results often costing the owner at least twice as much to repair properly. Cast iron welding should not be attempted even by experienced welders without years of high temperature oven welding training. Cast iron requires preheat of at least 900 deg. F. for brazing and 1300 deg. F. for fusion welding
/ Lifting capacity #37
I understand the concept but have no idea how to calculate; however, in the attached photo I was lifting a 400 lb beam at the tip of the boom. The beam is 14 ft long so the center is at 7 feet. I had no feeling of tipping, in fact I carried two of these beams off the trailer at one time and had no sense at all of being light. I did not try three as that would have been at the total advertised capacity and I did not want to try it.
/ Lifting capacity
Does everyone know that the PT's lifting setup is a Class three lever setup, which has a fixed fulcrum point, fastened at the frame., The point where the hydraulic cylinders connect to the arms, is called the effort. The load is the third part of the lever, and on the PT, I believe, that it is the point where the Quick Attach is connected. Feel free to correct my observations.
/ Lifting capacity
Which model PT do you have. I can see that it is red.
/ Lifting capacity #40
I appreciate what the article is saying, but what I am welding is not as critical as say an engine block. I will not be drilling and tapping it or machining it in anyway. I just want it to stick to other metal. Given that is there still a problem? J_J, I am not trying to be difficult here, it just seems that for my limited application there is not really an issue. Or is there?
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
2018 Merlo TF30.9-115 (A64119)
2018 Merlo...
2019 Forest River R-Pod RP-191 Travel Trailer (A61574)
2019 Forest River...
2005 Peterbilt 357 Tri-Axle Dump Truck (A61573)
2005 Peterbilt 357...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
