lifting arms
/ lifting arms #1
jack707
up North wisconsin
farm trac 555
I bought a 2 bottom plow yesterday and I noticed the pins on the plow are a lot smaller then the ends of tractor lifting arm ends (BALLS ON THE END) IT'S. 3/4 MY TRACTOR TO 1\2 PLOW SO CAN I USE LIKE IT IS OR CAN I CHANG THE ENDS?.
/ lifting arms #2
I would either change it or buy some bushings. Using bushings is pretty standard when mounting a Class I implement on a Class II tractor 3 point hitch.
/ lifting arms
OK I see different sizes at fleet farm so how do I change the bushings.
/ lifting arms #4
Here are the dimensions for the lower and top link pins.
You can find lower and top link bushings at TSC (or similar ag stores).
Steve
/ lifting arms #6
Jack,
The bushings are just sleeves the slide over the lower and upper pins to match the size your tractor needs.
Or you can buy and replace the pins on the implement with the size you need.
/ lifting arms
OK now I understand just like shims that fit into the holes.
/ lifting arms #9
If you have no need for the smaller pins (like for a smaller tractor) then just buy the Cat I pins that fit your tractor and swap them out on the implement. Pins aren't that expensive and once swapped you don't have to worry about loosing the bushings. I used some bushings once when I first went from a Cat. I to a Cat. II tractor (I still had the Cat I tractor)and left the implement hooked up for a long time. When I tried to get the bushings out of the ball ends, they were seized in so tight that I couldn't drive them out. I had to take a cutting torch to them to remove them which is a tricky business to cut thru the bushing without damaging the ball on the tractor.
You may have to cut the old pins off with a grinder or torch if they have been on for years or threads have been damaged but that is not a huge problem to do IF you have the equipment. If you don't have a 4 1/2" grinder with 1/16" cut-off blades, wire wheels and 1/8" abrasive blades, now is the time to get one and some consumables to go with it. Harbor freight has some pretty good ones for about $30 (get the one with a paddle switch). I also take off the 4 screws holding the head on and replace the low grade waxy lubricant with some good grease. That quietens them down a bunch and makes them last much longer. They are so cheap that I have 3 of them to complement my one Dewalt and they all work as good as the Dewalt brand that cost 3 times as much.
/ lifting arms
Well the rain let up enough to get the tractor out and unload the plow from my pick up, as far as the dia. I need the plow holes are 1/2inch and my tractor are 7/8 the top link fits.
/ lifting arms #12
Change the pins. If you really have 1/2" pins they're too small for a two bottom plow anyway. Jim
/ lifting arms
Well what have have to do now is take my 4 1\2 grinder with a cut off wheel and cut the pins and weld up two 7\8 pins in place.
/ lifting arms #14
No way or place to use bolt-on pins? I'm amazed your 1/2" pins aren't bent.
Jim
/ lifting arms
That's what I have there no place with threads so I have to cut and weld it on.
/ lifting arms #17
Can anyone explain the presence of 1/2" pins for the lower links? That's smaller than for a Cat. 0.
Steve
/ lifting arms
The plow is a Ferguson type 12-2 28 number 40982 I guess someone could look it up.
Portable Concrete/Mortar Mixer (A66408)
Portable...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Bobcat Turbo 873 Skid Steer (A62679)
Bobcat Turbo 873...
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
