Lifting Arms on H1502
   / Lifting Arms on H1502
#3 is the shaft that the eye lifting bar attach to for the 3 point hitch.
   / Lifting Arms on H1502 #12
I think as long as you have your lift arms on and the corresponding hitch pins and sway chains you can remove the centering bar (part #4 in the diagram shown previously). I have problems with mine also but it's not that the bolt breaks, more that the centering bar bends. You might also want to consider installing collars instead of the centering bar like shown here to eliminate the problems associated with it:
Cross Bar for 3 PT Hitch Kubota Iseki Other Tractors | eBay
The shaft is the anchor rod which is long enough to support both lift arms , spacer with spring clips on both sides to lock them on .
   / Lifting Arms on H1502 #14
After looking for a picture of the three point assembled, I see that that length is needed. As above you might be better off using a bearing lock ring on each side.
2021 Polaris Ranger Electric Utility Cart (A56857)
2021 Polaris...
TANK MANIFOLD (A55745)
2020 MACK P164T (A58214)
2020 MACK P164T...
2014 PETERBILT 579 (A58214)
2014 PETERBILT 579...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
Heavy Duty Skid Steer Breaker (New/Unused)(Est. Retail Value $4,800). (A59225)
Heavy Duty Skid...
