Lifting a building with the 2520 and the 70.
   / Lifting a building with the 2520 and the 70. #1
BlackRaptor
SEMN
John Deere 3320
I got tail weight for it now I figure i have about 600LB on the 3 point and i got the tires filled.
So now I figured I can get this dang building moved.
Figured i would share some picutres.
I know it doesn't look very safe but both tractors were well weighted down and the 70 did the loader moving then the 2520 would match it we took it very slow.
Here are the rest.
And no he's not standing under the building. ha-ha
   / Lifting a building with the 2520 and the 70. #3
A more graceful ballet I've never seen.
Somebody needs pallet forks for Christmas....
   / Lifting a building with the 2520 and the 70. #4
Yeah, that gave me some ideas, Hmmm.
   / Lifting a building with the 2520 and the 70. #5
Nice work!
BTW, do you know how many gallons the rear tires on teh 2520 take? I got mine filled before it was delivered but the dealer didn't pay attention to the # of gallons. I'm just trying to ballpark how much weight is actually added.
   / Lifting a building with the 2520 and the 70. #8
Birdmayon said:
Nice work!
Draw a line on each side of the tyre where the water level is ie. 10-2 o'clock reverse the tractor until the back line touches the dirt ie 6 o'clock , mark the dirt where it touches . Drive forward until the front mark touches the dirt and mark again . Remove tractor and measure between marks in centimetres . measure the width of the tyre and imagine the tyre on the ground as a pipe between the 2 marks . Multiply 1/2 the diameter X 1/2 the diameter X 3.1416 X the length and that will give you the litres . 1 litre = 1 kilogram .ie if the tyre diameter is 30 cm and the marks are 200cm apart , the sum would look like this :- 15 X 15 X 3.1416 = 706.86 X 200 = 141 litres = 141 kilograms X 2.2 to get pounds = 310 pounds per tyre .
   / Lifting a building with the 2520 and the 70. #9
LBrown59 said:
I don't think forks would have worked as good on this job?
Sure they would! I remember moving a large press base, weighed about 10K lbs, with two fork trucks, 6500lb & 7500lb capacities each. Forks on the buckets would have been a little tricky, but IMHO safer than just using the buckets.
Iron Horse said:
I bet you nearly cakked yourself when you realised one loader was lowering and the other was not ..:D
Ha-Ha
then the 70 started lowering you could feel the weight on the 2520.
it made me pucker a bit but all in all it went smooth and was pretty easy and made for some interesting pictures.
the 2520 has so much power for it's size i'm amazed by it every time i use it.
Has to be the best purchase i've ever made.
(APPROX 13) 6" X 6" X 17' ROUGH CUT PINE (A54756)
(APPROX 13) 6" X...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2013 BMW X5 xDrive50i AWD SUV (A55758)
2013 BMW X5...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
SAMSUNG SMART REFRIGERATOR (A54757)
SAMSUNG SMART...
