lift stoped working
   / lift stoped working #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
my 3 pt lift quit lifting today,,then i realized i had hit the remote hydraulic lever.... i didnt have any thing hooked up on the remote,,when i put it back in place my lift worked ok for the rest of the day ...do you think i did any damage to any thing ?? thanks for any help...bruce
   / lift stoped working #2
No you didn't harm anything... the 3pt is typically the last thing in the hydraulic circuit, If you use a loader or aux hydraulic it uses all or most of the hydraulic energy before any gets to the 3pt. KennyV
   / lift stoped working #3
I grab the wrong (unconnected) remote lever sometimes by mistake and pull/push it. It just lifts the safety bypass valve. As a matter of fact, I have a pressure gage hooked into a quick connect and use it dead-headed in the quick connect to check hydraulic system pressure by pulling the remote lever and watching for the pressure to peak before the relief valve opens. No harm at all. If the remote lever were to stick open, the relief valve might heat up due to the constant flow of fluid, but you'd know there was a problem because the 3PH would not raise as you found on your tractor.
thanks for the help.. i feel better now... bruce
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
2002 Ottawa 30 Spotter Truck (A52384)
2002 Ottawa 30...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A51248)
UNUSED FUTURE...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
