Lift or mechanic's pit for new garage?
   / Lift or mechanic's pit for new garage? #81
In some cases, a pit might be a cheaper option.
The engineering, permitting (if even allowed) and concrete work to properly put in a pit now-a-days would not be DIY thing or cheap. Cost should not be the primary deciding factor though.
   / Lift or mechanic's pit for new garage? #82
I am planning out my garage for a new build. I plan on working on my cars, tractor and UTV in this garage. Which would be the best way to go? A lift, if that is even possible with a tractor considering how back heavy it is, or a mechanic's pit?
FYI. Tractor (Kioti DK6010SE + filled tires) is probably around 5,000 lbs but I may eventually upgrade to 100hp + tractor.
Why would you ever need to put a tractor on a lift?!? Sounds pretty silly considering that one can get all around a d under a tractor just as it sits .
   / Lift or mechanic's pit for new garage? #84
I had a pit and loved it. I have a two post lift now but wished I had a four post if not another pit. No weight limit. No falling off. I was on a hillside so it had a drain. I had a built in shelf with air and water connections. I used a ladder but later laid blocks for steps. I never put a cover over the pit but you could.
   / Lift or mechanic's pit for new garage? #86
Still an issue with my asymmetrical lift. I have felt strips on the drivers post.
I am stealing that idea.
The above video's have a lot of failures due to the individual arm locks failing- assuming they actually have them in the first place.
   / Lift or mechanic's pit for new garage? #87
I would definitely do a lift. I had a three Rotary four-post lifts and loved them. I was able to stuff seven collector cars in a garage built for three. A sliding pan system catches oil, so no worries about drips. I would think a pit would always be in the way when not using. Personally, I would not be comfortable putting a tractor on a lift because of the weight, unless all the numbers showed it to be safe. (I have a series 3 John Deere, no longer 1026R.)
   / Lift or mechanic's pit for new garage? #89
Lifts, especially 2post, are like anything else, need to be installed properly, used properly, and maintained properly.
I've never seen a failure of a properly maintained lift, usually it is operator error or lax maintenance (which is always surprising because they require very little maintenance).
Although I haven't installed or used a really cheap lift enough to speak to them.
4 post are great for storage and quick fluid changes, even tire rotation/brakes of it have built in scissor jacks, however 2post are way more versatile.
There a reason my uncles shop only has a drive on lift for the alignment rack now, the other 12 lifts are all 2 post, both above and in ground.
Sent from my SM-S921U using TractorByNet mobile app
   / Lift or mechanic's pit for new garage? #90
All I got to say is that the pit will always work although you need to install ventilation in it.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
2023 PJ Dump Trailer (A55973)
2023 PJ Dump...
2002 Henderson FSP Sandspreader Attachment (A55973)
2002 Henderson FSP...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
