Lift or mechanic's pit for new garage?
   / Lift or mechanic's pit for new garage? #51
I am planning out my garage for a new build. I plan on working on my cars, tractor and UTV in this garage. Which would be the best way to go? A lift, if that is even possible with a tractor considering how back heavy it is, or a mechanic's pit?
FYI. Tractor (Kioti DK6010SE + filled tires) is probably around 5,000 lbs but I may eventually upgrade to 100hp + tractor.
Before I relocated to warmed regions, I had a pit. Complete with air, power, and a ventilation system, which is critical. I miss it every day. If I could do it again next week, I'd go with a pit again. Design it carefully. Do not allow your wife to sweep the floor into it.
   / Lift or mechanic's pit for new garage? #53
My 4 post is old. There are 2 beams that run the length of the lift and a frame on each end that locks into the columns . I can block the spring hangers to the beam and then lower the ramps to do tire and brake work. The ramps provide a nice work surface to put tools on but sometimes they get in the way trying to reach up to get to the fuel pump or power steering pump.
I did make some plywood boxes to fill in between the ramps when the ramp is down so I have a close to even surface to walk across when I am not using the car hoist.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2011 Kenworth T7 Series (A55973)
2011 Kenworth T7...
2020 TCTC 16ft T/A Landscape Trailer (A55853)
2020 TCTC 16ft T/A...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2012 PJFS25 Goose Neck Trailer (A55973)
2012 PJFS25 Goose...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
