Lift cylinder for Kuhn disc mower
   / Lift cylinder for Kuhn disc mower #1
CaptainQ
I have a gmd 66 kuhn disc mower, I was wondering if they can be repaired and if so where and if anyone knows where I can buy a new on other than from the dealer or Kuhn. Mine is leaking out of the seal and it does not look serviceable.
Thanks,
Carl
   / Lift cylinder for Kuhn disc mower #2
I bet it can be rebuilt. Ask the dealer about a rebuild kit. Also, you might try a local hydraulic place. Cylinders get rebuilt all the time.
D.
The cylinder looks like it was put together at the factory and the welded at the factory it is closed on one end and does not have a snap ring on the other nor does it look like it was screwed together. My problem is it is only a 1000.00 dollar mower that we a going to use for a home school project and I hate to have to buy a 400.00 cylinder for it, I was told a cylinder off of a N.H. 462-463 or a J.D. 260 would be the same as a Kuhn GMD 66.
   / Lift cylinder for Kuhn disc mower #5
Yeah, might be sealed - I am no expert on them. Might check Tractor Supply or even a tractor scrap yard. I bet you can rig something up.
D.
   / Lift cylinder for Kuhn disc mower #6
On the end that is not welded there should be an access hole (pipe plug) to remove the retaining ring. I've never done it, but have seen it in a service manual.
   / Lift cylinder for Kuhn disc mower #7
Can you post some pics of the cylinder?
I have dome the style that mlauk describes. They are not fun.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Fuel Tank (A51573)
Fuel Tank (A51573)
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
