Jul 4, 2019 / Lift arms on MF TO35 not dropping down #1 J jasperab Bronze Member Joined Jun 26, 2008 Messages 74 Location Beaufort, Mo. Tractor MF 230/Mahindra 4500 MF TO35 Arms were slow to drop to begin with, now not dropping at all. Tried hooking up heavy blade and got them to come down once, but when I started tractor they came back up all the way and won't drop.
Jul 4, 2019 / Lift arms on MF TO35 not dropping down #2 RNeumann Elite Member Joined Aug 29, 2016 Messages 4,143 Location North Idaho Tractor Mahindra 1538 Have you adjusted the flow/speed control between your legs (typically) when seated?
Jul 4, 2019 / Lift arms on MF TO35 not dropping down #3 D Dave M7040 Elite Member Joined Dec 10, 2012 Messages 2,757 Location Williamstown Ontario Canada Tractor Kubota M7040 Nuffield 465 This is a question not a statement. Position control on some tractors confuses owners. Sometimes the position control, if present, is a second lever apart from the main lift lever. If the position control is set to a high position, it will slowly raise the 3 pt arms to where it was set regardless of the main control. Dave M7040
Jul 5, 2019 / Lift arms on MF TO35 not dropping down #4 H Harry in Ky Veteran Member Joined Jan 27, 2012 Messages 2,334 Location Winchester Ky Tractor Allis Chalmers ED 40 Check your PM inbox.
