Lift arms on MF TO35 not dropping down
   / Lift arms on MF TO35 not dropping down #1
jasperab
Bronze Member
Beaufort, Mo.
MF 230/Mahindra 4500 MF TO35
Arms were slow to drop to begin with, now not dropping at all. Tried hooking up heavy blade and got them to come down once, but when I started tractor they came back up all the way and won't drop.
   / Lift arms on MF TO35 not dropping down #2
Have you adjusted the flow/speed control between your legs (typically) when seated?
   / Lift arms on MF TO35 not dropping down #3
This is a question not a statement.
Position control on some tractors confuses owners. Sometimes the position control, if present, is a second lever apart from the main lift lever.
If the position control is set to a high position, it will slowly raise the 3 pt arms to where it was set regardless of the main control.
Dave M7040
   / Lift arms on MF TO35 not dropping down #4
Check your PM inbox.
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A51692)
2017 Freightliner...
DEUTZ-FAHR 5110G TRACTOR (A51247)
DEUTZ-FAHR 5110G...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
Sany SY35U Pro Mini Excavator (A52384)
Sany SY35U Pro...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
