lift arm pins
   / lift arm pins #1
tonyw
NC
YM1401d
Anyone know a good source for replacement lift arm pins? One of mine came loose and fell off while I was tilling...I'd had trouble before with the nut coming loose, and should've had sense enough to put some Locktite on it... /forums/images/graemlins/blush.gif
thanks!
   / lift arm pins #2
If you are talking about the upper one.(part of the tractor), probably a dealer. For the lower one, (part of the implement), any tractor parts/supplies place such as TSC.
   / lift arm pins
Thanks, Norm! Sorry, I meant to mention it is the upper lift arm pin on a 1401d.
Thanks!
   / lift arm pins #4
Tony,
The 1401 did not have lift pins originally. They were probably installed as part of the 3pt conversion. They are likely either category 0 (5/8") or category 1 (7/8") 3pt lift pins. They are available at any tractor store. Just take the old one with you to get the right size.
   / lift arm pins
Thanks, Greg! It's cat. 1...just didn't know if those things were readily available...and might have to order it. I guess I'll try Tractor Supply.
Thanks again!
   / lift arm pins #7
never hurts to have an extra pin or two around,will save a trip out when you realy don't feel like it,and you always have trouble ,when you want to use tractor. murphey's law
lippy
   / lift arm pins #8
TSC does carry the upper pins for most tractors I put a new set on mine after i noticed one was bent assuming it's cat 1
   / lift arm pins #9
Tony, the upper arm pin on your YM1401 should be 3/4" with 12mm threads, the pin should be 3 9/16" long. I have them in stock if you can't find one.
Danny
Parker Equipment Co
   / lift arm pins
Thanks to everyone for your help! Danny, I'll be in touch....
Sorry it's taken so long to reply...we just had a new arrival on Thursday, a baby girl, so my mind is elsewhere! /forums/images/graemlins/grin.gif
Tony
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
BROWN BDH-600 LOT NUMBER 174 (A53084)
BROWN BDH-600 LOT...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
