Lift arm mount bracket (ripped out)
   / Lift arm mount bracket (ripped out) #1
stray
Platinum Member
east TN
Power-trac 422 2003 model and 428 January 2015 model
It looks like I shook my mini hoe muck bucket a little too hard one time to many
This is the piece prepared to be installed and welded. A シ inch plate larger than the ripped out hole is welded to the ripped out piece to insure a good weld backing and to add structure.
Fit and slide it in place from the back side.
Pull it tight, and then from the back side smack it with a hammer to be sure it is up tight and in place.
Weld it up good and reinstall. Back in business!!!!!!
   / Lift arm mount bracket (ripped out) #6
Wow, you certainly got the job done. Nice Job! :thumbsup:
   / Lift arm mount bracket (ripped out) #7
How long from start to finish do you think it took you to complete the job? Just curious. Good job by the way.
Thanks guys. It took about 3 hours. Counting the preparation of the mount piece. Guess I can get back to cleaning that pond out today.
   / Lift arm mount bracket (ripped out) #9
Looks good.. and stronger than the original.. now you know what to do with the other side when it rips out:laughing:
James K0UA
   / Lift arm mount bracket (ripped out) #10
Hello Stray,
I noticed that the failure occurred on the side where you added some sort of red square tubing holder (just above the mount). Could it be possible that the custom work you did would have weakened the original mount...?
Glad nobody got hurt,
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
2016 JOHN DEERE 8245R LOT NUMBER 182 (A53084)
2016 JOHN DEERE...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A51573)
Vermeer D16X20A...
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
