Lift arm control
   / Lift arm control #1
avillahdw
Avilla, AR
2013 LS U5030
Hello Everyone,
Just wondering if anyone out there has come up with a way to raise/lower the lift arms from the rear of the tractor. I believe some models of Mahindra offer this and I can certainly see where this would be handy when hooking up implements if not using a quick hitch.
   / Lift arm control #2
I would like to know. My fenders have punch out that look like a place for switches.
   / Lift arm control #3
I don't need to access my controls, but I have in the past used a cane and another member simply uses a notched piece of PVC pipe.
   / Lift arm control #4
It's hard with the cab in the way.
   / Lift arm control #5
Guess it depends on the tractor, I just opened the back glass. I no longer use any open station tractors.
   / Lift arm control #6
I also open the back window.. and use a 1 1/4 piece of pvc about 4 ft. long with a groove cut one inch from the end.. I slip it over the lever and push or pull to lift or raise.. I have 5740C Montana and 990 John Deere,, Lou
   / Lift arm control #7
You guys are better climbers or taller I could see me falling back on the hitch. It's not to bad I work left to right then I am near the door when I can work it pretty easy.
   / Lift arm control
On my U5030 (non-cab), the lift arm control is down beside the right side if the seat, which is no problem as long as your in the seat. The ease if having a rear accessible control would be nice. I have a plan floating around in my head and if it works, I'll post pics and details. As this is a new tractor, I do not have my hydraulic top link or quick connect on yet.
   / Lift arm control #9
You mean like the one on the back of my Kioti?:). It doesnt look like it would be that hard to build some mechanical linkage to do this.
   / Lift arm control #10
I know rub it in.
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
