lifan 13 hp motor mount bolt size
   / lifan 13 hp motor mount bolt size #1
Brimfield
Mass
Kubota L 3800
I am going nuts building a log splitter. I can't find what size and pitch bolts mount the pump to the motor. I have looked all over including the manual but no luck. It's a 13 hp lifan engine that is said to be a Honda clone. The owners manual is a joke to say the least.
   / lifan 13 hp motor mount bolt size #2
M8 or M10 std metric would be the logical choice to try.
   / lifan 13 hp motor mount bolt size #3
For things like this, a good selection of well labled test bolts is helpful.
Also, 8mm and 5/16 are close enough to be mistaken for each other.
I had a bunch of bolts to try and I was at my wits end. I took it to a real hardware store not the big box ones and found out it was a 10 mm 1,25. Big box stores had 10 mm 1.5. I got it all together but I still need to get all the hoses.
   / lifan 13 hp motor mount bolt size #5
Have this on hand:
Innovative Components AH-COM Thread Detective/Thread Identifier Inch and Metric Combo set. Steel identifiers strung on a wire lanyard. Permanent, chemical resistant, tested and approved size markings won't peel off. Shatterproof, color coded gauge
2023 UNVERFERTH 432 LOT IDENTIFIER 32 (A53084)
2023 UNVERFERTH...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A51248)
UNUSED WOLVERINE...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2023 John Deere 6R 155 MFWD Tractor (A53342)
2023 John Deere 6R...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
1994 HONDA 300 FOURTRAX ATV (A51247)
1994 HONDA 300...
