Leyland 245 Power steering
   / Leyland 245 Power steering #1
arjay
Victoria
Kubota B6100
The power steering has given up and there are no oil leaks. I don't have a manual so where is the best place to start?
   / Leyland 245 Power steering #2
Check the fluid for the power steering system. My field boss 2 60 has a seperate reserve for this.
   / Leyland 245 Power steering #3
You dont say if you have checked the fluid level so I am assuming it is low. Internal leaks in the pump end up inside the engine and you dont see them.
If you have a Leyland you should join this forum: Peatland Export Parts - Home
I have a Nuffield and have belonged for years. You cant get better info and more help from people around the world.
I will pass along info from my 465 as I suspect it may be relevant to your machine. Note the need to fill the system at full right lock with engine running. Use GM transmission fluid called Dexron.
Many people fit a hose to the reservoir plug and use an external power steering reservoir from a car or truck to allow you to see the level easily and refill promptly.
Dave p
Thanks for the info and contacts, yes the oil level has been correct at all times.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
Light Tower (A52377)
