Lever to the left of Float lever
   / Lever to the left of Float lever #1
tsmithco
SW Ohio
2015 Kubota L5740
YM2002 - I have a lever that is to the left of the float up/down lever - but it doesn't seems to do anything. I have moved it when the 3point is up and down. Also, thinking it was a "stop" have adjusted and then moved 3point up/down to see if it stops sooner - but nothing....
   / Lever to the left of Float lever #2
I believe it's your draft lever. Good for only ground engaging equipment.
Eugene
   / Lever to the left of Float lever #3
Not familiar with your model but if it's like mine, it is called the draft control but it is not like a conventional draft control we normally think of. There is a cable that connects at the back of the tractor on the one end and a Yanmar tiller on the other end. By using the angle of the rear drag flap, it interprets the angle as depth. With it all connected up, the draft control will maintain the tiller depth fairly good.
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
Copper Eagle Weathervane (A57454)
Copper Eagle...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A57453)
2009 Chevrolet...
6ft Wolverine Sweeper (A57454)
6ft Wolverine...
