leveling yard
   / leveling yard #1
hoogy
Chester, Vermont
MF GC2310 HST
I have lived in my home for twenty years. The lawn has taking a beating. With cutting trees down and planting flower gardens and then moving them other places. The lawn has taking a beating. It is not level and bumby and rutty. What is the best way to level it back out and make a nice looking yard again.
Thanks Scott
   / leveling yard #2
Top dressing should take care of it. Use a mixture of sand, compost and top soil and spread it over the lawn and then rake it smooth. You should end up with a nice smooth level yard next year. If ruts are too deep that the grass can't make it thru the top dressing you will have to replant those places.
   / leveling yard #3
Top dressing is what I am doing & for me it is the best way.I have a lot of trees to deal with so tillers are out, box scraping sod is risky as I found ou the hard way, sent many trees into shock & might kill em. They don't like there roots ripped out,so I now top dress & looking for the biggest pull roller I can find.
Joe
   / leveling yard #4
jandg- try not to use the roller if you can help it with fresh soil. rolling can compact the soil, making it hard for grass seed to grow.
hoogy, have you thought about applying roundup to everything and then till it all in? then you should be able to plant new grass seed and fertilizer to get a nice lawn by next summer.
   / leveling yard
top dressing what are the ratio you use. I have a big yard almost a acre that i mow
   / leveling yard #6
Thats my problem hoogy. I am no expert but have read that 2" of top dressing is about what you need and that is a lot of good dressing material to come up with.
MarkV
   / leveling yard #7
Make it as you can via mommy nature and a compost pile.
Leaves. Buy/rent a shredder/chipper thingy. I have and Earthquake from TSC and LOVE the chipping and when the leaves start to fall it'll really be used to grind the leaves 20:1.
When you get a pile just add and add. Toss a tarp over it and let it cook.... A bit of water in the pile is momma's helper. Toss in grass clippings, straw or hay. Most seeds should burn up in the composting process. Tiny twigs, tree bark, veggie's you don't eat, etc.,
NO MEAT of any kind.... It works and works GREAT too.
This is cheap and gets you a little at a time at a very NO to low cost, unless up buy the shreader.
   / leveling yard #8
You aren't going to be able to cover an acre by making compost. It would take your whole life.
I have used 10 pickup loads of grass clippings (well over 5 tons) and once composted it doesn't even put 6 inches on my small garden.
   / leveling yard #9
I have the same issue, not too bad but would like smoother for kids to run on.
Topdressing must be done slowly, maybe a 1/2 inch a year--too much compost at one time can kill off the existing grass unless you use a mixture with more topsoil than compost then can use more. Stay away from sand if you have clay soil---clay + sand = cement!
What I hope to do once I get the tractor & tiller is what Radioman suggests and roundup then till and seed. I'll probably do sections over a few years to protect against what happened the first year---seeded all and got a few gully washer rains to create the ruts that made it rough. Makes it more manageable to water the new seed since I don't have sprinklers and about 1 1/4 acre of grass.
   / leveling yard #10
Does your county have a recycling center that takes in yard waste? If so they might be selling it chipped up right cheap. Our's does.
2014 Electric Cart (A53424)
2014 Electric Cart...
Utility Trailer (A52377)
Utility Trailer...
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
