Leveling land
   / Leveling land #1
future_vision
New England
DK6010SE HSA
I'm working on a new home build which is on a slope. It's going to have a walkout basement so part of the slope is taking care of but the rest I need to backfill. Trying to figure out what is the best approach to do this. Do I need to remove the organic material off the top before adding in fill or do I just add fill on top?
   / Leveling land #2
The problem with organic material is that it will shrink unevenly in the future.
Do you wish to minimize cracking of your foundation and sheetrock?
Fill will also need to be compacted.
   / Leveling land #3
Can you post picture?
   / Leveling land #4
Organic matter is not allowed in engineered fill. Fill must be reasonably wet and compacted in short lifts to insure uniform density.
   / Leveling land #5
Remove organic stuff down to native dirt. Water well to be sure it's settled. Use 5/8" minus as a fill then water and compact that.
   / Leveling land #6
+1 to what Roadworthy said. Additionally, topsoil is a precious thing and should always be scraped off first, to be used later.
   / Leveling land #7
Are you referring to filling under your footers and foundation (under the house) or outside the foundation after the walkout basement is complete to landscape the yard to the foundation?
   / Leveling land #8
Rock/gravel (compacted) under concrete. Clay/fill outside the foundation is okay. Topsoil goes back on top, last. IMHO
   / Leveling land
Outside of the foundation. For example, in front of where the house will be we would like a flat front yard. At the moment it's slopes. I'd say between 15-30 degrees. Ill have to measure it to be sure. Should the organic material be scrapped off and then filled and compacted with clean backfill before putting the loam back on top?
   / Leveling land #10
You should be good to backfill directly over the biomass...assume it's likely grass or mixed weeds you are covering with dirt to then seed your lawn.
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2018 Toro Sand Pro Bunker Rake (A49461)
2018 Toro Sand Pro...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
