Leveling ground with disc
   / Leveling ground with disc #1
LabLuvR
SC
Kubota MX5400
I had a fellow come over with his huge hydraulic disc to do my fields while I over came knee surgery. The fields look great but I see some places where he left me a few places with a ridge and valleys off to the side. I just need to knock the crown down a few inches into the valleys to level things out. Should I set my disc to be aggresive or least aggresive?
   / Leveling ground with disc #2
I would just leave your disk set up however it already is and make a few passes over the problem area. Then get a log and connect a chait to either end of it to create a log drag so that you can smooth it all down. With a small 5ft disk and an oak log, I've been able to smooth out some very rough land.
Eddie
   / Leveling ground with disc #3
Slight bite on the front, and almost straight in the rear. Work shallow and at a good rate of speed. It'll be good enough to pull those 71s over.
   / Leveling ground with disc #4
Lab, drag ridges w/blade-grade box to valleys. chop ridge and repeat if neccessary.I don't kwow what kinda ridge you got?(get pocket eye level cheap home depot) W/pocket eye level gota get low to ground to look/check.when look good, then drag whole field w/rr-rail iron. make sure your valleys are not natural drains.You may cause unatural sink-hole looking standing water by filling valleys? my2cents:) Also chain link fence makes nice smth/finsh job. valley fill make take 1yr. to settle/pack try to seed w/something right-away.
Got it fixed. Thanks!
2012 DIAMOND CARGO FOOD TRAILER (A53843)
2012 DIAMOND CARGO...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
