leveling bumpy field
/ leveling bumpy field #1
greenjchorn
I have purchased 33 acres of gopher heaven. I have about 10 acres that I want to hay. What would be a good implement to level out the mounds? I have a plan to reduce the gophers, but I think I will still need to level it a bit every year. I would like something that I can use without totally tearing out the grasses. I have access to a neighbor' small full size tractor.
/ leveling bumpy field #2
Landscape rake with side wheels should work ok for this project.
/ leveling bumpy field #3
If the dirt is still pretty loose I would take a pretty good size(20') piece of hog panel and throw a ramp or some other type of object that weighs a good bit on it and drag it around over all of the mole hills. This is the cheap way to do it, but it has worked for me.
/ leveling bumpy field #4
Sorry to show my ignorance, but what the heck is a Hog Panel??
thanks,
jb
/ leveling bumpy field #6
After looking at the hog panel link I see that I was calling the utility panel hog panel. But either way I think any of those panels would work. Another good thing about pulling the panel behind your tractor is that it doesn't require figuring out how to use a box blade or landscape rake, you just pull it around until every thing is good and level.
/ leveling bumpy field #7
You are looking for good hay and no gophers?
Suggest a rethink involving full cultivation and replanting with grasses desirable to your area. The cultivation will get rid of the gophers and also help smooth out the field.
If you have a pasture full of gophers chances are the grasses growing are not the most desirable.
Egon /forums/images/graemlins/grin.gif
/ leveling bumpy field #8
I think your best bet is to get rid of the gophers first by trapping or something like that. Leveling the mounds will only make them move on to anohter spot and dig up.
murph
I have advice from the local 80 something gopher trapper that I am going to act on as soon as ground thaws. My property is bordered on two sides by state park so I don't think I will ever be totally free of them. Still considering plowing under and replanting though - I think I could do better on the grass species currently making up the field. Thanks for the advice so far.
/ leveling bumpy field #11
JohnB,
Yep, just like in CaddyShack........no.......wait that was plastic explosives /forums/images/graemlins/grin.gif
/ leveling bumpy field #13
After plowing and disking my garden, which was covered with woodchyck holes I used 2 old bed springs to even out the bumps. The old metal ones, not the newer box springs.
/ leveling bumpy field #14
</font><font color="blue" class="small">( After plowing and disking my garden, which was covered with woodchyck holes I used 2 old bed springs to even out the bumps. The old metal ones, not the newer box springs. )</font>
=<font color="pink">===== </font>=
I'm trying to decide if I should plow and disk .6 acres
Or just till it in preparation for planting grass.
<font color="red"> Which way to go? </font>?
/ leveling bumpy field #15
Till.
Pack back down with a packer or harrow - tiny seeds like firm soil.
--->Paul
/ leveling bumpy field #16
Ag department of Saskatchewan has a great video on getting rid of gopher hills:
Mole Hill Levellers - YouTube
Most of these are mods of existing equipment. Typical machine is one spring loaded chisel plough or heavy duty sweep cultivator. Remove the sweeps and bolt a 4" to 6" grader plate (#8 bolts) Each grader attaches to at least 4 spring bars. Worth a look
/ leveling bumpy field #18
Since you just purchased the property you could also chisel plow the field and destroy the under ground burrows. Just leveling the field is temporary at best as the pesky rodents will just resurface.
/ leveling bumpy field #19
You realize the OP was in 2006?
159120 (A60430)
159120 (A60430)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
