LEVELING A MOWER DECK
/ LEVELING A MOWER DECK #1
KEYBEAR
Indiana
John Deere X-758
I have a 60 inch drive over deck and it is almost a year old . I have a problem keeping it level from side to side . The two adjusters used to do this use two long bolt,s and I think they may be backing out and letting one side move down ? I level it and after 10 or so hours of mowing the left side is low maybe a half inch .
I am thinking of putting a lock nut on them .
/ LEVELING A MOWER DECK #2
A lock nut or just a black marker pen to note if there is any movement like "backing out".
If I knew the Thread of that bolt I would just put a nut on it and call it good . I may watch it until I remove the deck .
Rain all day today so I pulled the deck off . Everything looks good so I added a lock nut will see how that works .
/ LEVELING A MOWER DECK #5
Did you check the tires to see if one side is loosing air?
/ LEVELING A MOWER DECK #6
I had a 770 with that system. It did not work well on slopes as the deck would lean. I was going to ask about the air in the tires as well.
Just put new tires on it last week the original tires no problems with air and so do the new tires .
1979 AM General 6X6 Truck (A61165)
1979 AM General...
Massey Ferguson 461 Tractor (A61166)
Massey Ferguson...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63118)
2023 New Holland...
INOP/NON-RUNNING 2005 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDL85HN88678 (A61165)
INOP/NON-RUNNING...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2001 JOHN DEERE 770CH MOTORGRADER (A62129)
2001 JOHN DEERE...
