jlgurr
Veteran Member
- Joined
- Oct 21, 2013
- Messages
- 1,024
- Location
- Bostic, NC
- Tractor
- Massey Ferguson GC1705, John Deere STX46
Ok, for some this may be a silly question but curiosity is getting the best of me... Came up on it again this weekend with a small project. My FEL is narrow enough that I can usually lean to the side and be sure the bucket is level with the ground. Noticed some have installed their own indicators and also that some tractors even come with one from the factory. What I have not seen is an explanation as to how they indicate level.
The reason it nags at me is because the "angle" of my bucket to make it level with the ground changes depending on the height of the ground relative to the tractor as well as the forward/rearward tilt of the tractor. Another way to say this might be that if I was working on a raised ledge in front of the tractor then my loader bucket will be closer to full tilt but still level with the work because the loader is already up in the air a bit.
So does the bucket level indicator take into consideration the height of the work? If it doesn't does that mean it is only accurate when the working height is in the same plane as the tractor tires.
Thanks,
Jeff
Thanks,
Jeff
