Level a Bumpy Yard
/ Level a Bumpy Yard #1
koop
Madison Virginia
Case IH 495
What implement can be used to level a bumpy yard. My yard is too large to realistically fix everything by hand. If there was something I could pull behind the mower that would slowly flatten the area, that would be a dream come true. Perhaps a core aerator would allow the plugs to fall into the low areas over time. I am willing to be most patient.
Thanks in advance.
/ Level a Bumpy Yard #2
You're on the right track with the idea of core aeration. Core aerate and top dress with compost or compost/sand mixture, depending on your soil composition now.
Is part of your bumpiness clump forming grass? I have experienced that. Start a program of Spring and Fall aeration and overseeding with a good quality turf grass that is suited to your growing conditions. It will eventually crowd out the clumping fescue.
Another issue worth mentioning is irrigation. Nothing you can do will change a bad yard into a showplace faster than irrigation.
What would be the efficient way to spread compost into just the low areas. To top dress almost three acres by hand would be time consuming.:eek: The bumps are caused by several factors. Mostly the lawn was an old pasture or wooded thus never finish graded. Some mole damage and some erosion.
/ Level a Bumpy Yard #4
Only one tool that will do what you want
Disc Harrow
and lots of time and it will come out great
Jim
/ Level a Bumpy Yard #5
Disc Harrow
Jim
Koop:
I agree with MrJimi. I am currently running an "experiment" on my bumpy lawn. I am filling in the low areas with fill and tilling the high areas. I have used both my landscape rake and/or my boxblade to level everything out. In hindsight I should have mixed in some composted manure in with my heavy clay based fill to lighten it up and fertilize as well as maybe have used a fresher grass seed. Next week should tell how well this "technique" will work. Jay
/ Level a Bumpy Yard #6
Disc Harrow
Jim
I think that saying there is "only one tool" to do this job is a little over the top.
koop specifically mentioned that he wanted a long range, and I assume minimally invasive, solution. Disking up the whole yard and starting over will work, but it is not the only solution. Aerating, topdressing, and overseeding on a regular basis will get results in time and without the disruption of a complete overhaul.
koop: re: spreading compost and top dressing.
I bought a used Turfco Mete-R-Matic tow behind model from a golf course and rebuilt it. I use it two or three times a year on about an acre of lawn. They also make a really dandy walk behind powered unit. Check out http://www.turfco.com
I have heard good things about the Mini-Topper from Bannerman. Go to this link, then go to Products>landscaping>topdressing>mini topper
http://www.sportsturfmagic.com/
/ Level a Bumpy Yard #7
I just read my post and what I meant to say was a spike harrow
I have and use one and its great and will do exactly what he wants done
sorry about my mistake
:eek:
/ Level a Bumpy Yard #8
Just mow really really low and sharpen your blades often. It will all get leveler with time.
/ Level a Bumpy Yard #9
You have the patience that I don't.
I would Round-up the area, rent/buy a rototiller for the rear of your tractor/machine, level it out, and reseed. I am waiting until August/September and will be box blading about an acre where the seed didn't take that was planted around 6 weeks ago.
Good Luck in your decision!
Thanks for all the helpful info.
61" Turf Tiger already is working to level area by scalping high areas LOL:D
Spike or chain harrow vs a core aerator are the leading contenders.
Any thoughts on the better product?
I do not need a golf course, just a few teeth to eat dinner after I cut the grass. Currently, running top speed leaves me only with baby food as an option for supper.:p
Thanks again!
/ Level a Bumpy Yard #11
Use them all... The harrows will get a quicker leveling result, but do not replace the need for core aeration. That is something you should be doing (at least every fall) regardless of how smooth the lawn is...
/ Level a Bumpy Yard #12
I Feel your pain. I normally have to get off the tractor 3-5 times while mowing to pee, the bumps kill me.
I bought an old farm house and the 8 acre field that came with it (was about 2 ft high). Prior to me purchasing the property, I had the previous owner cut the field. Well, 3 years later and I still have ruts all through it. The moron apparently had the tractor in 3rd or fourth gear flying through the field.
I paid a contractor a couple of times to cut it, they had 4-5 60-72" cutters working on it at a time. He got a little upset that it was busting up his equipment, so he didn't want to do it anymore. So, I abused my little lawn tractor, scapling the ground everytime I cut it, cutting in opposite directions each time. I filled in the ground hog holes, and the very deep ruts. Everytime I do a little addition to the driveway, or increase the size of my garden I take the grass and dirt and put it in bad areas. Then I bought a compact tractor, lawn roller, FEL.
It isn't great yet, but it is better. I filled the lawnroller with dry sand, and roll the field periodically after it rains. They tell you not too, that it will cause damage, but it seems to flatten some of the bad areas out quite well.
I'm waiting for a bigger tractor to make the rest of the yard into a golf course. At least that is what the old farmer next door keeps laughing about. He wants me to let another farmer bale it. I find it helps to keep the field mice and other rodents away, and lets me see the deer,turkey, pheasant etc clearly from the back window.
I wish you luck. Now if I only had a couple hundred thousand, I could buy the farm across the road and all that beautiful acreage. Life is so cruel.
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2008 EPI FRAC MANIFOLD TRAILER (A67714)
2008 EPI FRAC...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
Hitachi Zaxis 135US (A64911)
Hitachi Zaxis...
2010 ICX Platforms Towable Skywatch Tower T/A Trailer (A66734)
2010 ICX Platforms...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
