Lets test some grease!
   / Lets test some grease! #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
Lets see how a low end grease compares to Lucas Red and Tacky
   / Lets test some grease! #2
I’m actually surprised how much difference there was.
   / Lets test some grease! #3
supertech sells a red grease, not sure why it wasn't the comparison as its literally a dollar more, which i have used for years on everything including trailer bearings. 0 issues for me
supertech red
   / Lets test some grease! #4
supertech sells a red grease, not sure why it wasn't the comparison, which i have used for years on everything including trailer bearings. 0 issues for me
supertech red
You could spend a year testing grease and not test them all. Testing a grease that cost half as much vs grease that’s nearly the same price is a better test IMO.
   / Lets test some grease! #5
I have never seen a grease related failure.
What does a grease failure look like, other than the obvious of having no grease. I mean, if there is grease in the joint or bearing, and it fails because of the grease, how can a person tell?
   / Lets test some grease! #6
Most of the time a joint that was actually well greased never fails at least on residential equipment.
   / Lets test some grease! #8
For this board, where most of us use our tractors less than 200 hours/year it's probably more important to make sure it's all greased than worry about the specific brand of grease.
   / Lets test some grease! #9
Generally a grease related failure is from incompatible types of grease. Many people flock to polyurea because it synthetic but if you look at a grease compatibility chart it reacts bad with just about everything. We see this at work all the time when mixed with lithium it turns to a rock as a prime example
   / Lets test some grease! #10
I've seen grease failures two times forsure...
The grease failed to stay in a properly greased bearing, so the bearing failed...
That's a grease related failure.
SR
Swamp Buggy (A49346)
2005 Ford F-250 4x4 Reading Crane Service Truck (A48081)
2005 Ford F-250...
8ft. S/A Utility Trailer (A48082)
8ft. S/A Utility...
2013 Volkswagen Passat Sedan (A48082)
2013 Volkswagen...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2023 Stryker 36ft. T/A Gooseneck Flatbed Equipment Trailer (A49346)
2023 Stryker 36ft...
