Flail Mower Let's talk flail mowers
   / Let's talk flail mowers #7,511
It's been a long wet spring here in the Pacific Northwest ...
Anyway, my tractor is Ford 1310 (manual gearbox) with only 19 hp engine and this mower otherwise seems to be a perfect match with it.
View attachment 748128 View attachment 748129 View attachment 748130
Any opinions - should field "hay" like that require two flail mower runs?
I am impressed with your job as-is. Also that the 1310 handles the 5ft flail well. Only you know how smooth you really want that field. If it is an open meadow (as it appears to be) I don't see any reason to mow it closer. As with most ground if you mow it multiple times it gets better/cleaner each time. If you want it smoother I'd wait a week and mow again and just do that until you are happy with it. "Half way to wall" each time (!)
   / Let's talk flail mowers #7,512
You are probably right. I have never seen that type of one-sided bent-style knives all supported by a common rod inside (apparently.) Alternating rows of left pointing vs right pointing. Pretty interesting design. Like you, I am guessing it is pretty old and not something currently sold. And for sure if he is going to use it he needs to come up with castor wheels of some kind! [A whole lot cheaper than adding a roller.] The post holes are still there and look serviceable -- probably just a matter of measuring the diameter of the holes and searching around for castor wheels to do the job.
Look behind the knives in that first picture, looks like a roller, unless I am mistaken.
   / Let's talk flail mowers #7,513
Thew biggest issue after the first mowing was the hay that got bent over by the tractor tires....
I did the second run in the opposite direction and it worked out pretty good.
   / Let's talk flail mowers #7,514
Good catch -- you are right. I failed to see that. If you look real close it is slightly visible in the last picture too. Makes you wonder which (wheels vs roller) was the original configuration. Or maybe the machine was made to accommodate either one.
  • Good Post
Reactions: Lnk
   / Let's talk flail mowers #7,515
Flail mowers/flail crop shredders can have gauge wheels
in front or the rear to help keep the mower level from
front to back to protect the flail mower rotor.
   / Let's talk flail mowers #7,516
My old Ford 917 came with a roller & caster parts. Caster rims were toast & removed before I got it. All rusted out. Never fixed them & just removed the mounting frame for them. Pretty sure all that was OEM. Used the roller that had been welded fixed many many years before I got it.
Not sure of the value having both, but some came that way.
   / Let's talk flail mowers #7,517
The rear casters/gauge wheels are for higher cutting heights than the rest roller is capable of cutting and rougher terrain due to the larger diameter.
   / Let's talk flail mowers #7,518
Yes, it does have a standard roller like most flails. I’m going to try and get some gauge wheels for it. The blades are toast and will require a good sharpening before I use it next. I love not having windrows and I can’t wait to see the quality of cut with sharp blades
   / Let's talk flail mowers #7,519
This ^^^^
Also typically you only see rear wheels on crop shredders. For normal use as a flail mower the rear roller works better.
  • Good Post
Reactions: JWR
   / Let's talk flail mowers #7,520
Do you have a source for new blades? I've found new knives for my antiquated Alamo flail are very inexpensive. If yours are too, it might pay to replace them rather than to try to sharpen them. That way the whole batch would represent a full set of spares for you which could be sharpened as needed.
1994 SUNDOWNER 4 HORSE GOOSENECK TRAILER (A52708)
1994 SUNDOWNER 4...
2025 Forklift Safety Basket (A56857)
2025 Forklift...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Sellick 560 Forklift (A57148)
Sellick 560...
2007 38ft. T/A Homemade Pipe Trailer (A55973)
2007 38ft. T/A...
