Flail Mower Let's talk flail mowers
   / Let's talk flail mowers #4,271
I have time to wait on a good deal on a used flail. I have two decent riding finish mowers and a walk behind DR 26 inch brush mower, so I don't have to get a flail right away, and I'm only mowing a little less than two acres, including about 0.8 ac with the DR about five or six times a summer. That part has several 3 inch high stumps in it that the DR just rides over. I guess a flail would too, but they might catch and bend the roller. The rest of the place is hayed by a local farmer. Most of my budget was blown just buying the tractor.
   / Let's talk flail mowers #4,273
Sorry to hear about your old flail leaving you....
As far as "duck foot hammers", are there two kinds of duck foot blades? My Dandl has duck foot blades but I wouldn't call them hammers, might be 1/8" material thickness. Just wondering....
LNK
Those aren't hammers, those are scoop knives, just another grass cutter.
   / Let's talk flail mowers #4,275
That's a 88 inch cut...way too much for my tractor.
I ran a 7' Ford 917 flail behind my L3200hst... 32hp, 25hp PTO (not even factoring in the several HP I loose living at 6,200').
If you can lift it, you can spin it. Just likely need to go slower, but you cover similar ground. Going slower is easier on you & your machine. Maneuverability can be an issue though.
   / Let's talk flail mowers #4,276
I still have a flail mower on my wish list. I've searched the forums in general as well as this thread as best I can but I still have a few more questions.
Right now we're using a 5' Rotary cutter (and aside from sickle bar mowers & various hay cutting mowers/haybine/diskbine) it's all I've ever known.
What we mow:
The greatest majority of what we mow is just tall pasture growth. Not enough cattle to keep it eaten down so when it gets knee to mid thigh and/or tassels out to seed we knock it over (or cleaning up corners of the hay fields where they can't get). We have done a lot of work to get the old blackberry vines, briars and saplings cleared up and have very little left so I'm not worried about cutting small trees, bigger limbs, mulching, etc.
I do have a small pond (spring fed), short section of creek, and a 300-400 feet of steep / tall ditch & road embankment that I can't mow with anything directly behind the tractor.
How much & how often we mow it:
Small jobs like cleaning up corners when they mow hay, keeping a half acre lot mowed down, and mowing the roadsides will probably account for about 1 acre total area mowed 3 to 5 times a season
The "big job" cutting the pastures (I think we have about 12 acres total cleared now) is a once maybe twice a year job depending on the season.
What I'm thinking:
I was looking at hydraulically offset / rotating flail mower. Had my eye on the Made in China brands for a while and even looked into importing one myself (ouch). Then another forum member put me on to Betstco and I have tentatively settled on the AGL-145 (wanted the 165 but per their specs I'm not quite heavy enough in the tractor department)
57 Ditch Bank Flail Mower w/Hammers Installed AGL145 57" Ditch Bank Flail Mower w/Hammers Installed [AGL145] - $2,199. : Betst Products LLC, Rugged Labor Saving Equipment Since 1995
While looking at E-Bay, I noticed they offer the 165 at $2,402 OBO - and that they accepted an offer of $2,045.99 last Nov. E-bay says they have sold 6 have "more than 10" available (Web site says 21)
The 145 is listed at $2,199.00 none sold / no offers accepted. Availability: E-bay "More than 10", web site says 20
Their E-bay offerings are listed with Hammers but the web site shows the option of Y blades on the 145 (Hammers are an additional $120 upgrade)
So on to the questions
1) Blades
Given that the lions share of mowing will be field/pasture/roadside - would I be better off to stick with Hammers (I can always use the RC for more heavy duty stuff) or should try to negotiate for the Y cutters.
Also - how would hammers finish work compare to a RC (aside from distribution of the cut material not being piled into rows)?
2) Mower
I found a few threads about Betstco products and the majority seemed satisfied with the quality for the money. Obviously I'm not a commercial mower or looking to contract out to the Highway Department so I'm thinking with the correct PM & a little TLC this unit will do all I will ever need for longer than I'll be able to use it.
3) Price
Seeing as how they took a little over $350 off on a 165 plus the $120 "upgrade" cost from Y cutters to hammers. (and given the fact that they seem to have a large supply & small demand) ...
Would an offer of $1600 for a 145 with Y cutters be fair? Their E-bay listings do include shipping so I know that's a lot and I'm not trying low ball them but I don't want to pay more than I have to either.
(And I will also have to shell out another $800 to get the OEM rear remotes for the tractor so I have to factor that in my budget).
Thanks for the advice.
   / Let's talk flail mowers #4,277
N2DFire, You've obviously already done a lot of investigating but I'll make a few comments. First, I would personally go for the 165 with a CK35. You might need to go a bit slower in the heavy patches but the extra width will be appreciated when doing ditches etc. A CK35 is about as heavy as a Kubota or Deere 40hp tractor (just estimating) so it's not like the 165 is going to be a tail wagging the dog.
Flail hammers are going to give you a MUCH finer cut than any RC bush hog type mower. Probably not quite what a finish mower will provide but close. That said, I have Y blades on my Caroni TM1900 and I've never wished I had hammers or scoops. The Y knives on clevis hangers do a fine job with brush and grass. I certainly wouldn't pay extra for hammers.
I've only heard of Bestco flails here on TBN but I haven't heard of anything bad. My main concern with the Chinese flails is with the importer and whether they will be in business ten or twenty years from now. The Italian and US brands are much better established so supplies are less likely to be an issue in the future.
Regarding price, if you go with the 165 and have evidence on Ebay that they sold the 165 for a discount then point that out and see if they'd like to sell another for the same price.
   / Let's talk flail mowers #4,278
Are the EGxxx series (or AGL series) flails all close enough that parts from one seller will fit a flail from another?
They look pretty similar in pictures.
   / Let's talk flail mowers #4,279
Hello ND2Fire,
Before you waste any money call Iowa Farm Equipment as ask
about the Italian Del Morino boom flail mowers they carry as a
product line. They will ship them directly to you from Iowa.
   / Let's talk flail mowers #4,280
Are the EGxxx series (or AGL series) flails all close enough that parts from one seller will fit a flail from another? They look pretty similar in pictures.
Until and unless you have both information sheets with the description of the knives OR
each knife in your hand you will not know-the second option will save you a lot of money and grief.
Have you looked at the small Vrisimo flail mowers? they are built and sold in California.
16' Cattle Guard (A53316)
16' Cattle Guard...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
2012 Cadilac SRX SUV (A55758)
2012 Cadilac SRX...
2005 Ford F150 Pick Up (A47477)
2005 Ford F150...
NISSAN 60 MAST FORKLIFT (A55745)
NISSAN 60 MAST...
