Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #441
Reg said:
Good guess.
I discovered British standard plumbing parts to be the norm in hardware stores in Switzerland when I lived there and had to home repairs.
One of the little civilization things that the English brought to the rest of the world - sanitation.
Indeed. Where would we be were it not for John Crapper and his contribution to civilization.
/ Let's talk flail mowers #442
Thought;
"Oil bath" doesn't necessarily mean that everything has to be submerged in oil at all times.
There is probably adequate lubrication as long as the teeth of the bottom gear dip into the oil. From there is gets distributed via contact, right ?
/ Let's talk flail mowers #443
Reg said:
Thought;
Sorry , not correct . The outer shaft bearing will run dry if the oil level gets that low especialy when it is elevated whilst mowing slopes . As for the breather , i have made them before for other aplications . If it still throws oil out it is a simple matter to scrunch up some bird wire and place it in the pipe which stops the oil but still allows it to breath . I drill an 1/8" hole crossways through the bottom of the pipe and Braze a cross bar into the hole to stop the mesh from dropping (a piece of Brazing rod works well for the cross bar ) When you need to refill the box you just need to unscrew the pipe .
/ Let's talk flail mowers #444
IslandTractor said:
Now, where in the colonies can British standard pipe be purchased?
I'd use an adaptor to convert to standard pipe. Discount Hydraulic Hose (Discount Hydraulic Hose.com) should have the fittings. Perhaps it is even the same thread as the CCM top links.
/ Let's talk flail mowers #445
GinNB said:
Also...
The Caroni shift kit comes with hoses that terminate in couplers that are different to Parker, not sure what they are, but...
Unscrew the coupler and... Ta Dahh, the hose has a (male) BSP end.
For a small number of Colonial dollars female BSP to make NPT adapters can be had from a local hydraulics parts place, e.g. where they sell repair bits for snow plows & such.
So, for the breather tube extension DIY project you can probably buy a variety of BSP parts where you see the Fisher plow sign, or Curtis, Boss, etc.
/ Let's talk flail mowers #446
IslandTractor said:
I think you are right. The 3/8" is dead on according to the measurements I made yesterday.
I live in Canada and it isn't exactly standard issue. In fact, I don't know of a single place that stocks it. Or can order it for that matter, but then I haven't really asked. If I needed some I'd start asking at a place that worked on or installed irrigation equipment. Some of that is European and uses BSP.
/ Let's talk flail mowers #447
I did check them out and they do in fact carry a number of adapters. I have ordered a couple each 3/8 BSP male to male and a couple 3/8 female to female connectors. I'll try one set and see if that is adequate and if not will extend it with the second set.
Before I lose the part numbers, they are 9000-06-06 and 9043-06-06 respectively. Cost about 11 bucks per set.
I'll let you know how they work in a week or so.
/ Let's talk flail mowers #448
I'm still waiting on my Rears SPF.
Should have been here last week. I called about it today. They will let me know.
/ Let's talk flail mowers #449
Mine, from a different distributor, is 'in' a/o last thur. They are still trying to construct a plan to deliver it to me. Odd in this recession/slowdown they are so busy that they deem it more efficient to delay the 90% delivery payment.:confused:
larry
/ Let's talk flail mowers #450
I don't know about mowers but agriculture in general is definitely NOT in a slowdown. Demand for big tractors, combines, tires, fertilizer, diesel, etc etc is WAAAY up, and so are the prices. There is a waiting list for a lot of things. Corn, beans, wheat, rice, etc are worth a lot more than they used to be a few years ago and farmers are trying to cash in big and are spending big to do it. Many suppliers are having trouble keeping up with the demand.
/ Let's talk flail mowers #451
I would have expected a half decent design to include some sort of oil slingers to get the oil out to the ends of the shafts.
Mayhap we're just talking early 20th century ag-tek here, so maybe not.
OK, so it has to be at least up to the bottom of the uphill seal, worst case that probably means FULL !
I was referring to the Caroni gear box atop the mower, not a lot of height difference in that little box when its tipped side to side.
/ Let's talk flail mowers #452
If you got plumbing ...you got BSP.
If you get snow ...you got BSP.
SOMEWHERE ...you got BSP.
Check with your local hydraulics guys, wherever the back hoe guys get parts, wherever the SNOW plow drivers get parts.
Canada gets snow,
Canada has indoor plumbing (in some parts).
/ Let's talk flail mowers #453
NPT is not equal to BSP, or so I've been told. NPT is the North American standard, BSP is the British standard used in Europe.
As far as indoor plumbing goes, I'm a farmer. It's optional, but appreciated. :)
/ Let's talk flail mowers #455
Reg said:
How do you manage to mow without a PTO shaft ?
Is this the shaftless option I've heard so much about ?
I bet it runs really quiet.
Now that's funny! noooooo, I'd just off loaded it from the trailer and was getting ready to disconnect, had removed the PTO before snapping a pic.
/ Let's talk flail mowers #456
I have seen a number of used units lately at dealers in 3 states, it seems that a lot of people are taking advantage of the deals out their in the lawn abnd Garden, and compact levels of equipment.
/ Let's talk flail mowers #457
GinNB said:
If you're fresh out of donuts and friendly machinists, try an air die grinder with a cylindrical carbide burr. Donuts are cheaper though. :)
I just used one of these for the first time a few months ago. I had one of those "Why didn't I get this years ago" moments.
I mean the burr, not the donut.
/ Let's talk flail mowers #458
ksimolo said:
NPT is not the same as BSP, you are correct.
Ken
Reg seemed to think that I was in Britain I guess. NPT is the American (and thus North American) standard.
/ Let's talk flail mowers #459
McMaster-Carr has BSP to NPT adapters.
McMaster-Carr
Search on bsp and you will see bsp to npt
/ Let's talk flail mowers #460
McMaster-Carr
For the Caroni oil vent cap you'll actually need BSP male and BSP female connectors as the vent cap itself is BSP. McMaster-Carr does sell these but the only BSPP female to BSPP female connector I found is a swivel type which will not work as the cap won't be in tight enough to prevent the fitting from leaking.
Discount Hydraulic Supply has the male to male and female to female connectors needed. They are cheaper too.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
3PT POST HOLE DIGGER (A64278)
3PT POST HOLE...
2003 Sterling L7500 S/A Day Cab Truck Tractor (A64556)
2003 Sterling...
2022 International LONESTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2022 International...
2022 EZ-GO ELITE...
