Lets see your Woodworking Skills
   / Lets see your Woodworking Skills #51
I am simply blown away from the talent on this site. Thanks you all for the great pictures. I can see many years of trial and error has went into the fine work that's been displayed so far. Keep those pictures comming. :applause::applause::applause::applause: ~kid
   / Lets see your Woodworking Skills #52
image.jpg This is a corner hutch I made for the wife back in '05. It's my favorite because its also my first and 100% by me
image.jpg this table was built shortly after (cant take credit, helped my cousin)
These don't hold a candle to you guys. These are stain grade birch. I mixed three parts thinner to one part gloss black enamel to make a stain. Then over the course of several days put three coats of polyurethane over it. The legs on the table are treated posts from Home Depot that we cut. FYI, chairs are from JC Penney:)
   / Lets see your Woodworking Skills #53
Wow awesome things guys! thanks for starting this post. The stirrups, are they put into a form after being steamed?
All the work looks great.
Robbyr,
Are you bending the stirrups in a RF Press? It looks like (I may be wrong) they are laminated. With that radius do you use top and side pressure on the forms and alternate the grain direction on the inside layers? Great looking work.:thumbsup:
   / Lets see your Woodworking Skills #55
They are laminated. All of these ( our higher end ) are six laminates. We also make blanks that are four. Get a log out of the pasture. It's cut into roughly 2x8 form. Then these are cut into blocks two feet long which are then sliced on a Baker resaw and sanded to try to get correct thickness. Predominant wood is oak but also use quite a bit of elm, pecan, walnut, and occasionally a few others. The blocks get soaked overnight in a pot with heating element and allowed to cool before being sliced to thickness. There are various molds for the different styles of stirrups. A hub that the wood is bent around with an outer shell which is hinged. Open up outer shell, put the wood in, close shell with hydraulic cylinder. Most of the equipment in shop was self built by my dad or cousin. I don't have an inventive mind. Nettlescountry.com
   / Lets see your Woodworking Skills #56
Good Mornin David,
That drop front desk is absolutely beautiful ! Thats by far some of the nicest work I have seen on this site. Thanks for sharing, I thought my work was pretty good until I saw your projects....
This is a sofa table I built for my son a couple years ago...
   / Lets see your Woodworking Skills #57
Good Mornin David,
That is a nice table Scott.:thumbsup:
Your picture background is nice too! I can recall climbing around on them when new in the dealers lot!
   / Lets see your Woodworking Skills #59
I'm not much for the fine detailed stuff but I sure do like complicated:
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2018 FORD F550 XL SINGLE CAB SERVICE TRUCK (A51243)
2018 FORD F550 XL...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
