Snow Let's see your snow removal equipment
   / Let's see your snow removal equipment #161
I know mine is the other orange.
No OEM or Aftermarket cab available so this is what I use. Not pretty but it keeps me dry and warm.
   / Let's see your snow removal equipment #162
This unit not only moves snow we groom snowmobile trails with it....
The other unit we run is a Pisten Bully...
   / Let's see your snow removal equipment #163
ummmm, wow doesnt seem quite enough to say...
   / Let's see your snow removal equipment #165
Thanks Wayne!!! Plexi is on the bench and ready to cut to fit. I need to notch both sides to go around the canopy brackets tho. How's the best way to cut the plexi without splitting it? Jigsaw, hacksaw? Thanks.
Sorry for the delay, sort-of forgot about this posting! I went ahead and drilled to small holes at the inside stop location and then used a jigsaw to cut out the unwanted plexi.
Then I drilled small holes and used tie-wraps to secure the sides to the ROPS. I have used the same plexiglas for three years now so it has held up and there are little if any scratches on it.
   / Let's see your snow removal equipment #166
FINALLY (nevere got any pics last winter)-- got the FEL off, blower on .... This is the set-up that shaved my snow removal time by almost 70%.
"BEFORE" & "AFTER"
  • blower 12:1:08.jpg
    blower 12:1:08.jpg
   / Let's see your snow removal equipment #167
Here is my low cost snow plow. I took an old 6 foot Western snow plow ($100), welded up a bracket and mounted it to the frame of the loader (after I removed the loader). Rather than running the hydraulics off the tractor, I used the plow mounted hydraulic pump and simply wired in a control switch running to the battery. The plow works great and is not so far out in front like the loader mounted plows. Does everything I need to do.
   / Let's see your snow removal equipment #168
Picked up this older Woods SB 52 a couple months ago, pretty good shape. Repainted it with 2 part epoxy paint with rust inhibitor now just waiting to try it out.
Any other new pictures with the snow falling now. I found a few videos on You Tube that were great.
CASE SERIES 3 WT CRAWLER DOZER (A52709)
CASE SERIES 3 WT...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
2015 Puma TUK-13030HGE Air Compressor (A55973)
2015 Puma...
16 BLADE DISC HARROW W/ 1PT HITCH (A52708)
16 BLADE DISC...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
Auger Drill Bit (A56857)
Auger Drill Bit...
