Snow Let's see your snow removal equipment
   / Let's see your snow removal equipment #201
this is my toy
   / Let's see your snow removal equipment #202
The dynamic duo. They both have their place on my property. 500' blacktop driveway -- very poorly situated. LOTS of blowing and drifting snow.
The ATV is good for lighter snows and/or cleanup. It's small, light, fast and easy on the lawn.
The B3030 with the FEL and blower can bust through anything we get and dig out any major drifts that the ATV can't handle.
Together they do the job nicely.
If I'd gotten the tractor first, I'd never have bought an ATV or plow to go with it. But as long as I already owned the ATV/plow when I bought the tractor, it makes sense to keep it.
   / Let's see your snow removal equipment #203
Bandit,
I like your cab and tinted glass! I have a "Carhart Cab" for my 3030 but no tinted windshield yet. Great idea.
   / Let's see your snow removal equipment #204
OK, here are some pics of the snow rig in action with all the accessories. Check out the new Mad Bomber heated cab, along with low-light tinted windshield. I also have music in the cab (iPod in the shirt pocket). :D
Cab and windshield are easily removable each time I park the tractor. :D
Excellent:) I love the chains on all four tires. Did you have to reverse the front wheels (as I did) to accommodate the chains?
   / Let's see your snow removal equipment #205
Bandit,
I also have a lighter weight orange Cabela's "cab", but it's for the not-so-cold days. :D
   / Let's see your snow removal equipment #206
I did NOT have to reverse the front wheels. Chains fit perfectly, and I can turn the steering wheel lock-to-lock without worrying about the chains hitting the sheet metal steering shaft shield.
I did have one of the links on the rear brushing up against the fender, but it didn't even rub the paint off - just need to twist that portion so it stays clear. Pretty tight fit, though.
   / Let's see your snow removal equipment #207
I have a similar plow for my ATV, but I buried it in the storage shed so I wouldn't be tempted to get it out this winter, after cursing being without my hydraulics for one winter. I have thought about hooking it back up for the small storms, but the tractor is still faster, and a lot more "fun". :D
   / Let's see your snow removal equipment #208
Here is what I use.
My Toro is about 18 years old. It is called an 824 Power Shfit. The wheels articulate (forward and back) to increase down force on the blower. This unit has been a back saver. I've only had it serviced once in the 18 years and its still starts on the first or second pull.
This is my Kubota and JRW combo
   / Let's see your snow removal equipment #209
Here is what I use.
That is the exact thrower I have! The 824 has been the most reliable unit I have ever had. The only replacment parts I have ever needed are the skis.
Doug
   / Let's see your snow removal equipment #210
Me, too! That sure looks shinier than mine, however--
Mine still starts on the second pull after sitting for weeks, but I have had to replace the impeller once and the impeller bearing twice (rocks). Am now on the 4th set of belts-- but it's still a lot safer than the tractor/blower close to the house & garage.
Replaced the leaking shut-off valve with a piece of copper tubing this winter-- but all in all it has been very dependable. The Power Shift feature, before I got the tractor & blower, was very useful for going up my rather steep drive and still keeping the business end on the ground. Guess mine must be 14 or 15 years old, too. Seems like it must have several hundred hours on it. Don't plan to get rid of it any time soon!:D
It was barely affordable for us when we bought it, but has turned out to be a good investment. I'm looking forward to the M-F GC2310 being the same.
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A58018)
2005 PETERBILT 379...
1982 FIAT-ALLIS FR10 WHEEL LOADER (A52708)
1982 FIAT-ALLIS...
2014 Toro Z-Master 5000 Series 72in Zero-Turn Commercial Mower (A56857)
2014 Toro Z-Master...
