Let's see your Kubota
   / Let's see your Kubota #422
   / Let's see your Kubota #423
This beauty is bullet proof. I went 15 years without touching it, weeds grew up through the and into the cab and engine. I filled up the tires put in a battery and she fired right up. Last oil fluids change and fill up, was 1995. Worker her hard from the 80's till 95, never greased a thing on it, the loader pins are wore in half when I took the loader off. All the teeth on the front gear on the chain for the hydro pump was worn completely off, I put on a new gear and she's good to go. Three years ago I changed the fluids one her other than that not a dime in repairs.
Today I haven't started her in another three years and I left the same battery in her and she fired right up, and I graded a road with her for 8 hours.
This beauty will still be tilling fields long after I'm buried.
   / Let's see your Kubota #424
<img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/420974-lets-see-your-kubota-img_3894-jpg"/>
So how much you want for her?
   / Let's see your Kubota #425
Best pic I have at the moment. yes your eyes are not lying to you. those are straps. I got my chains the next day :)
   / Let's see your Kubota #426
Started fixing the drive from the winter plowing season.
   / Let's see your Kubota #427
I hope I look that good when I get old.:thumbsup:
   / Let's see your Kubota #428
Here is my latest orange toy. No doubt it's the most versatile machine I have. Next goodie will be some type of mowing head for those hard to reach places.
   / Let's see your Kubota #430
This beauty is bullet proof. I went 15 years without touching it, weeds grew up through the and into the cab and engine. I filled up the tires put in a battery and she fired right up. Last oil fluids change and fill up, was 1995. Worker her hard from the 80's till 95, never greased a thing on it, the loader pins are wore in half when I took the loader off. All the teeth on the front gear on the chain for the hydro pump was worn completely off, I put on a new gear and she's good to go. Three years ago I changed the fluids one her other than that not a dime in repairs. Today I haven't started her in another three years and I left the same battery in her and she fired right up, and I graded a road with her for 8 hours. This beauty will still be tilling fields long after I'm buried. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/420974-lets-see-your-kubota-img_3894-jpg"/>
If I only used it for 8 hours once very 20 years I might treat it the same. HS
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Troy-Bilt 20in Push Mower (A55973)
2016 Troy-Bilt...
yellow ball Trailer (A56858)
yellow ball...
2001 Ford F-650 Water Truck, VIN # 3FDWF655X1MA82619 (A57453)
2001 Ford F-650...
