Lets see everyone's front guard/grill!
   / Lets see everyone's front guard/grill! #1
BTackett
Knoxville, Tn
I am going to be adding a front guard/grill with weight and wanting to see ideas or mfg's of some. Just something simple like a downsized Ford 3000 guard and add weights.
Any ideas? I have a 100lb chunk now.
Bill
   / Lets see everyone's front guard/grill! #2
Stock 3203 JD had only the outer frame, I added the expanded metal mesh to protect the lights and added the brackets to hold up to 9 15lb lifting weights, the weights are held on with a 1.25" solid shaft with bearing lock collars to hold it all tight. Works great and only took about an 1 hr or so to do. Excluding paint dry time.
   / Lets see everyone's front guard/grill! #3
3" channel. Initials made from 1/8 x 1/2 flat bar
   / Lets see everyone's front guard/grill! #4
I built two of them. One for a 4110 John Deere and a second for a TC 55DA New Holland. The new Holland guard has fasteners welded into the frame work so a piece of mesh can be added for working in the woods. Those fancy hoods are expensive.
   / Lets see everyone's front guard/grill! #5
A 6 inch piece of well casing filled with concrete works as a guard and a front weight.
Nice Cab Jerome!
Keep the pics coming.
Bill
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
202483 (A54757)
202483 (A54757)
2022 Horizon Trailer (A55973)
2022 Horizon...
2012 DODGE RAM 1500 CREW CAB PICKUP TRUCK (A57880)
2012 DODGE RAM...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
