Let's discuss deer fencing...
   / Let's discuss deer fencing... #1
SanDucerro
Yoakum, TX
Kubota M7040 - L3130 - ZD326S
I need to fence off 4 acres and protect said acreage from deer. Internet research indicates there are a million and one (exact number no less) ways to keep deer off your property. And the cost for the various solutions seem to vary almost as much. The "given" seems to be the deer can jump higher than you can build. The trick is to convince the deer they don't want to jump the fence to begin with.
So, based on the above given - what's your fence look like and - more importantly - how's it working?
   / Let's discuss deer fencing... #2
Our electric fence is only 5' and it keeps deer out, but I don't understand why. We don't care if the deer come inside, the fence is for horses, and there's so many deer around here that the county is paying the ag dept to send in sharpshooters and harvest them. We have 6 wires, 4 are hot, two are ground.
The last place I worked had a biological field study going on, and they fenced off certain areas with a 10' high fence, no electric. That excluded the deer.
The places around here that grow grapes have fences that look to me to be about 8' high, not sure if they're electric, they must be working or there wouldn't be any grapes.
You know you can buy little bait things that look like bottle caps that you attach to the electric fence wire. They're sweet so the deer lick them, then they get a shock. That teaches them to stay away from fence (supposedly). If someone put cookies on the fence I'd eat them and take the shock.
That's everything I know about deer fencing.
   / Let's discuss deer fencing... #3
Every day you go out at sunset, drink a case of beer and then pee all the way around your four acres.
No really I had some bookmarks on stuff like this I'll try to dig up. One local golf course has 10' woven wire. I'd hate to know how much the posts alone cost!
Well, the quote I just got for 2000' of 8' fixed knot using all pipe was $7.25 per linear foot. That didn't scare me (too much at any rate), but then they wanted $360 a day for lodging and said it would take them 8 or 9 days... and then there was something about additional bracing at $465 each (and there were multiples of that no less). So... On to plan "B"...
   / Let's discuss deer fencing... #5
I'd like to know the answer to this question myself. I have fenced off about a quarter acre of my front yard for years to protect our ornamental shrubs from them deer, but the last two years they've been getting in somehow and it's driving me crazy. Been using the 7' heavy black plastic deer fencing. This year I raised it up to 8' or so in most places by putting eye bolts into trees then running clothes line through the eye bolts, then zip tie the fencing to the line every 4' or so. Used nails at the base of the tree to hook the fence and hold it down. If they're jumping it, I can't find an obvious marks in the snow where they're doing it. They come at night or early morning when we're sleeping, so haven't been able to "witness" it firsthand. Even looked into one of those motion activated cameras but it's a crap shoot where to place it, plus too much money.
I will say this - worked like a charm for years. I think we've got some smart-arsed deer that's evolved to figure out how to get in. Maybe I only need to get rid of that one deer? Arggg!
   / Let's discuss deer fencing... #6
I had no idea they could, I'd like to see it.
   / Let's discuss deer fencing... #7
I put up electric fence two years ago to keep the deer out of our gardens. I haven't had a problem since.
Now all I need to do is put up some of the white tape. They won't go near it even without electric.
I added a loop around our bird feeders last year to keep the racoons out. They don't come around any more either.
   / Let's discuss deer fencing... #8
I'm on my phone, so I can't look it up, but Premier One describes a fence method with offset electric and visual barrier. The electric is like two feet outside the physical fence. The deer hit the electric and stop. They would jump it, but they can see the physical fence and can't clear both, so they don't. You would have to do some research, as the spacing and height are important to get right.
   / Let's discuss deer fencing... #9
I'm on my phone, so I can't look it up, but Premier One describes a fence method with offset electric and visual barrier...
That was the one I was going to look for! Could not remember the name.
Offset fences are generally done with two 4' fences placed 3' apart. The fences are generally electric. I'd like very much NOT to electrify the fence. Since my particular needs are vineyard related, I need to consider the fact that my customers (we'll have a winery on premise as well) might wander over to take a look at the vines. Obviously, shocking my clients with anything other than my prices would not be a good business practice. That said, having an 8' tall fence is going to obstruct the view as well.
There are indications on the web that the offset fence doesn't need to be electric, so I'm wondering if anyone has done this without charging the fence. I'm thinking of two 4' fences, the first would use woven wire to control coons and rabbits and the second would be high tensil wire only. The thought is that the deer would come to the first fence, look over and see the second, and then move on.
Although - if I were to use a 6 foot fence in back with 4' of woven wire and the rest in high tensil, then place a 4' fence directly in front with high tensil only...
My thoughts on the 4' woven wire come from an assumption that I could do this myself. I don't have the same confidence level for 8' woven wire...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2015 CATERPILLAR 930K WHEEL LOADER (A51406)
2015 CATERPILLAR...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2017 FREIGHTLINER M2106 TELESCOPIC BUCKET TRUCK (A51406)
2017 FREIGHTLINER...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
