Lessons learned the stupid way
   / Lessons learned the stupid way #21
I was working construction one Summer, laying storm sewer at Wiley Post Airport in OKC. I was mixing grout for the guys laying the pipe. Behind my crew was a crew back filling and tamping the back fill with hand held air tamps...it looked like fun!
So, when they broke for lunch, I went over and picked up one of the tamps, squeezed the trigger, and it danced all over my foot. I lost a toenail in a split second...it literally fell off that night. Next day, trip to the shoe store for a pair of steel toed boots.
   / Lessons learned the stupid way #22
Early in my career (in another century) then were still using these ancient jumping jacks in trenches. They weighed hundreds of pounds and could kill you if you weren’t careful.
   / Lessons learned the stupid way #23
On my (former) JD D110 lawn tractor, the manual did not include a reminder or torque for the blade spindle 10mm 'screws' (4 per spindle) holding the spindle to the deck. Really, you would only notice them when you'd remove the spindle covers IOT change the belt.
After years/many hours, vibration (plus 'hitting things') will loosen a few of those screws.
I knew that "something" was wrong... the mower sounded 'wrong'... but there was no wobble on either blade. So, I just carried on mowing. Fortunately, when I did discover that one of the spindles was held on by ONE screw, I was able to replace the other three and no damage was done to the deck. (two screws were trapped within the spindle shield + the spindle shield screws were the same type, so I 'borrowed' one of them)
I've perused the Owner Manual for my new Z355E and, again, there's no torque setting for the spindle bolts. I'll inquire at my Dealership for this specification.
Admitting you have a screw loose is the first step :ROFLMAO:
   / Lessons learned the stupid way #24
Cut everything, drilled everything, welded, tried to assemble…welded the throw handle on the wrong edge of the angle iron. Since the leverage/geometry had to be offset I had to flip and offset the handle the wrong way when I redrilled. Dang it. Still worked though.
Todays lesson: Fire boots don’t have steel toes. I’ve spent my life in RedWing Loggers, steel toe and shank. Bought some RedWing, Wildland Fire boots. Everything looks the same except the Fire boots don’t have the steel toes and shanks. Put on the Fire boots, instead of my loggers before I went out to the shop to work on some cabinets.
I have developed a habit, of lifting sheet goods and setting them on the toe of my boots, and then reaching under with one hand to lift and carry them.
Tried that with the Fire boots. Knew immediately I had messed up. Big toe nail is a bit black tonight.
   / Lessons learned the stupid way #26
It's mid- July here. Hotter than the gates to Hell. My little lake is REALLY inviting. So - on with a pair of shorts - down to the dock on the far end. A wild run down the dock and a gigantic leap off the dock end.
Man - I just about pulled the "Jesus act". Walked on water almost all the way back to the dock. This water must have just come off an Antarctic glacier.
Tried just once and had a really steep learning curve. Now we wait until late August.
   / Lessons learned the stupid way #27
Yeah, easy to damage toes. I dropped a tire on my foot maybe 5 years ago (wearing sneakers). Nail kind of shriveled up and had to be cut off. When it grew back it was tender and splotchy/dark-colored. Doctor said it was the nail bed, and may never completely heal.
   / Lessons learned the stupid way #28
Heh. Had that happen to me once on a road trip, maybe back in the 80s. Had a pickup with a cap and was camping in state parks, etc. that didn't necessarily have facilities. Was in (I think) Wyoming, upper 90s and I was getting a little ripe (hadn't taken a shower in a couple days). Thought I'd go for a quick soap swim in a stream. Well...that was the quickest swim I've ever had. Dunked my head in to get my hair wet and saw stars!! That "water" was liquid ice! Once feeling returned, actually felt pretty good but lesson learned!
This would have been late August.
   / Lessons learned the stupid way #29
I rolled a canoe in 7' deep cool water. I swear I took an involuntary breath under water, but I don't know how that's possible.
   / Lessons learned the stupid way #30
Stationed out on St Lawrence Island off Nome Alaska back in 1955. July 4 55 a memorable date. 4 of use were sorta beachcombing along the Bering Sea, nice sunny day, water looked inviting. We all strip down and take a running start. I chickened out. The other three almost succeeded water coming back.
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2007 MACK CHN DAY CAB (A56129)
2007 MACK CHN DAY...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
