Lessons learned the stupid way
   / Lessons learned the stupid way #1
jigs_n_fixtures
Salmon, Idaho
TYM T233 & T293 CAB
The red dye in Dextron ATF, which my snow plow uses as hydraulic fluid, will dye translucent polyethylene.
i found this out the hard way, when the hydraulics on my plow quit working because the reservoir ran dry, and I pumped air into the cylinders.
I’d look at the reservoir and it was red 7 inches up on the 8-inch reservoir. Full enough my mind said. Really confused me when it ran dry. Had to laugh at myself when I finally figured it out.
Got it bled and working. Now I have to figure out some kind of a sightglass so I can tell how much fluid is actually in the reservoir.
   / Lessons learned the stupid way #2
The red snow wasn't a clue? :ROFLMAO:
   / Lessons learned the stupid way #3
When I use to cut firewood on my property. Went out to fell a couple ancient Ponderosa pines. The tree leaned - chainsaw got stuck in the cut.
All the way back to the shop to get my second chainsaw.
Future firewood activities always involved both saws.
   / Lessons learned the stupid way #4
Some years a fairly large pond forms on this end of my driveway. It's about quarter of an acre and two feet deep. It will flood across this end on my driveway. I usually use my 3" trash pump - over the hill and discharge into the large lake. It usually will lower the pond within three - four days - - 36 - 48 hours of pumping.
So ....... one year I got a real brain fart. Hooked up the PTO driven Wallenstein chipper. Backed the tractor out into the pond and ran the unit at 540 PTO rpm.
Man - it was discharging water, over the hill, like a 6" firehose. So .. I just made sure everything was set properly for a long bit of running. I settled into the tractor seat for a nap in the spring sun. No need to jump out into two feet of water and leave the tractor. I'd pump for a couple hours or so and see what it did.
I was RUDELY AWAKENED by the most horrific torrent of water - and it was ICE cold. For whatever reason this operation caused the discharge chute to slowly rotate. It was a bath that I really didn't need. I can still remember how very cold it was.
   / Lessons learned the stupid way #5
Some years a fairly large pond forms on this end of my driveway. It's about half an acre and two feet deep. It will flood across this end on my driveway. I usually use my 3" trash pump - over the hill and discharge into the large lake. It usually will lower the pond within three days - 36 hours of pumping.
:ROFLMAO: :ROFLMAO:
It had been two, possibly three, seasons since I checked the fluid level. And, that was when I changed out the hoses.
It has never developed a visible leak. The fluid level had slowly dropped over three seasons, and since the reservoir was 88% red I assumed that was the fluid level. Big OOOPS!!
What makes it worse, is it started acting low on fluid, and on most equipment I’m overly, **** about fluids and lube. Check fluids before starting. Then lube while things warm up.
I had a quart of ATF in the tool box, that has been there a couple of years, and I didn’t pickup on low fluid when it first acted like it was pumping air. If i had topped it off then, I wouldn’t have had sit out in the ass freezing cold bleeding the air out.
   / Lessons learned the stupid way #7
How does a wood chipper pump water? What happened to the oil if the machine didn't have a leak? Oil doesn't eveaporate. And it was obviously in there long enough to dye the oil level on the container. I'm not sure if I leaned something this morning or just got confused.
   / Lessons learned the stupid way #8
If the site glass is plastic, it will still eventually stain it.
Look at a pump with the top off. All that is in here is a centripetal impeller. Look at a the back of a snow blower, all that is in there is an impeller. The snow blower treats the snow as a fluid. The snow blower will treat water as a fluid to, and will pump it. Not as well as a closed pump, but it will definitely move water, if the impeller is covered.
   / Lessons learned the stupid way #10
First of all, I don't own a snow blower or wood chipper for that matter. The snow blower I get, but he didn't say snow blower, he said wood chipper. I suppose a wood chipper has a blower as well. Who knew.
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
2001 Volvo VNL Sleep Cab Truck, VIN # 4V4N19JF31N250304 (A54865)
2001 Volvo VNL...
greenworks (A53421)
greenworks (A53421)
City of Lakeland (A51691)
City of Lakeland...
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
