Lengthening BH bucket pin
   / Lengthening BH bucket pin #12
First of all take a look at the old pin. What is it made of? Scratch it with a file and hit it with a center punch to get an idea of the hardness. You may find that it is mild steel.
You want to replace it. Anything you use will be better than adding a section in the middle.
Secondly, what is the pin bearing against? If it is bearing against a cast surface then you would want to use a pin of mild or untempered steel. If it is turning inside of a hole punched into cold rolled mild steel then a chrome-plated or mildly hardened pin would be best.
Yes, using the smooth shank portion of a bolt would be an excellent choice. The standards for grade marking of bolts vary, but anything with hash marks on the head is a tempered alloy steel. Lean toward three to five hash marks if you can find them. Three to five indicates a bolt of grade 5 to 8 (ASTM) so is slightly hard but still very tough and drillable. More hashes are not better.
Good Luck, rScotty
   / Lengthening BH bucket pin #13
The harder the bolt the more that the holes in the machine will wear. I would rather replace a bucket of pins instead of a dipper. Just my take on it. big dan
I have not received the l39 yet its supposed to be getting here this week so I cant check the factory pin. I just assumed it was hardened. I assumed that because of two reasons 1. I figured that if it was just CRS it might bend enough to be a problem to get out if something happened. 2. I thought the pins in my B7800 where hardened but I have never pulled one out or inspected it closely so I could be wrong there also. I guess I will have to weight I just figured someone here had done this modification before around here and could chime in on what they used.
   / Lengthening BH bucket pin #15
i doubt that it would be anything but surface hardened, it would be to brittle
a 1" dia pin has more shear strength than most realize
Low Carbon Steel has 74,000 of tensile strength psi and 60% of that for shear is 44,400 psi
better steel will be more
Bolts and screws
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2006 Dodge Ram Pickup Pickup Truck, VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
