Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Farm.. I'm not talking about buying a new tube and welding it into a yoke.. I'm talking about taking a ..say.. 3" piece o f the tube, and welding it on to the end of the existing tube.. in order to make it a tad longer.. which it sounds like what was being sugested...
That would be like cutting an inch off a 4" bolt, and then welding it on to another 4" bolt to make a 5" bolt.. and then thinking it would be just as strong.. vs just buying the correct size bolt..
Soundguy
Soundguy
Farmwithjunk said:That shiney new factory made PTO shaft you can walk into most any farm supply store and buy was welded by SOMEONE. No reason to believe a good welder couldn't re-work an old one. Agri-Supply, Shoup, Valu-Bilt, and a host of other "mail order houses" sell the telescoping tubing stock to make those shafts.
Now.... Unless I was dead certain of my welding skills, I'd be a little gun shy of attemting this. Building your own PTO shaft obviously isn't for everyone. In the end, I doubt that it's feasable to build one cheaper than a good factory made one can be bought for.
Just because you want to know what time it is, you don't have to build your own clock.
