Rear Blade Lenght of KingKutter TRB-60-XB rear blade
   / Lenght of KingKutter TRB-60-XB rear blade #1
Speedy7
North East MA
Kubota BX23
Can anyone tell me how long this rear blade is? I need to know the length from where it attaches to the 3 point arms, to the end of the unit. Trying to determine if it will fit in my shed attached. It will go on a Kubota BX-23.
Thanks!
   / Lenght of KingKutter TRB-60-XB rear blade #2
I have the King Kutter RB-OT-60 model, I know that the XB series of King Kutter products are smaller than the other models for the specifically for sub compacts. I measured 31inches to 3 point hook up, and 35 inches to the front of the frame. There is no way the frame will be bigger(longer) on the XB series blade than the King Kutter standard rear blade. So if you have at least 31 inches, then your blade should fit no problem attached to the tractor. Hope this helps
31" from the furthest point at the rear of the blade to the 3-point attachment arms? That seems short compared to what it looks on the photo. But if that is the case, then I should be alright, as I have 46" clearance from the 3-point attachment point to the shed door. Thanks!
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
MULCHER (A58214)
MULCHER (A58214)
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2016 Komatsu WA380-8 Articulating Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel (A59076)
2016 Komatsu...
2020 Am-Tank 800 Gallon Fuel Tank, S/N 73348, Nominal Capacity 838 Gallon/3172 Liter w/Spill (A59076)
2020 Am-Tank 800...
Perkins 6 Cylinder Power Unit (A57149)
Perkins 6 Cylinder...
