lelft casing on the rear end Mitsubishi D1450 FD
   / lelft casing on the rear end Mitsubishi D1450 FD #1
ecmoth1
A 3 point hitch was attached to the rear using the same bolts that attached the casing to the rear end gear box. The hitch rotated causing one bolt to break off and bending 2 others on the left side. The case housing is broken or cracked where the 2 of the bolts go.
How do I get the case off? Does the axle have a keeper on it? Can the case be welded? Do I need to replace the case? Where can I get one?
I'm not to great in the mechanic field but have a good friend who is and is willing to assist me if I can get information on the tractor.
   / lelft casing on the rear end Mitsubishi D1450 FD #2
The case will pry off. There is no clip inside holding it up. While welding is a possibility, you may want to consider replacing the case. Call 1-800-609-5110 for parts availability.
Thank you Bill for the response will proceed and contact you if parts are needed
   / lelft casing on the rear end Mitsubishi D1450 FD #4
I have a D1450 parts tractor & can supply a used case if you want to go that route.
2008 Ford F-450 SD 4WD Pickup Truck (A53117)
2008 Ford F-450 SD...
JOHN DEERE 700M LOT NUMBER 239 (A53084)
JOHN DEERE 700M...
2015 Dodge Dart (A51694)
2015 Dodge Dart...
8' DISC HARROW (A51247)
8' DISC HARROW...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
40' CONTAINER (A51248)
